  • Guests: 71
problems with gatedriver
mb
Sat May 15 2010, 06:31PM Print
mb Registered Member #2485 Joined: Fri Nov 27 2009, 02:31PM
Hi,
i'm momently bluiding a Drsstc ,but now i have problems with the highside-gatedriver.
here is the schematic i'm using.
1273947698 2485 FT0 Drsstc Driver 2
Everytime when i turn it on without voltage on the brigde the (interupter-)signal at the gates is good, but when i turn the
brigdevoltage on its killing the Highsidedriveric (IC1/UCC37321).
Anyone an idea why?
the gatedriverboard:
1273948041 2485 FT0 Gatetreib
the Igbt: (datasheet:
Link2 )
Hope you can help me. smile
mb
Sat May 15 2010, 06:59PM
What is C12 for? Do you realise it will have the full HF bridge output voltage across it? I'm not sure if that's what's killing your driver, but surely it must add a lot of ringing on the traces.
