  • Guests: 69
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Looking for a 803 tube scoket.
Fri May 14 2010, 09:37PM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
Hi does anyone have a '03 socket they would like to sell/ trade. The socket is the same type that fits the 3-500z, 4-125, and 4-400.
Thanks,
Paul
Fri May 14 2010, 10:18PM
If everything else fails: Link2
Fri May 14 2010, 10:56PM
I serched all of Ebay. I don't want to pay more for the socket than the tube!
Sat May 15 2010, 10:33AM
There's two ceramic types on ebay here:
Sun May 16 2010, 10:14AM
Proud Mary wrote ...
From the description of the item "A Matched pair of #275 Ceramic Sockets"... I laughed a little :)
Sun May 16 2010, 10:47AM
I found it impossible to find Super-Jumbo sockets for a thyratron project, but was able to construct something just as good from the screw terminals inside the larger size of chocolate block connectors.
If you remove the screws, you can then push the terminal barrels out of the block plastic block, or just cut them out with a craft knife.
You can use these to clamp your wires to the valve pins, which means all you have to do is work out how you can best achieve mechanical stability - such as horizontal mounting in two padded U-bolts, or whatever suits your design best.
Bamacoiler
Wed Jun 16 2010, 05:38PM
Bamacoiler Registered Member #1628 Joined: Wed Aug 06 2008, 08:48PM
I have a pair of ceramic Johnson sockets. Will part with them for a decent price. PM if interested.
