  • Guests: 61
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
a fairly aesthetic polycarbonate enclosure for sale (US Only)
cavemen
Thu May 13 2010, 11:43PM Print
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
I accept paypal
Frederick Maryland
I SELL:
POLYCARBONATE WEATHERPROOF ELECTRIC/ELECTRONIC ENCLOSURE/WIRING BOX / Controll box
[img]
Physical description:
Aesthetic, sturdy, smooth, weatherproof polycarbonate enclosure has a gasket that goes along the seam.
The enclosure closes fitted with 6 machine screws.
Not predrilled. 4 small holes at corners for mounting screws.
Outside dimensions:
11 ¾” long by 9” wide by 3” tall
Can house a 8 ½ ” by 10 ½ ” circuit board with 2” tall components on it, facing up and ½” components facing down or any other panel of similar dimensions.
The circuit board is attached by 4 polyethylene studs that need 3/16” hole to snap in to, on the circuit board. The studs snap into the textolite plate. Or the board can be screwed directly to the case.
This includes:
* sturdy polycarbonate enclosure with 6 machine screws
* textolite plate
* 4 polyethylene studs
* 4 machine screws
1273794203 2008 FT0 Sd539880
ShawnLG
Fri May 14 2010, 04:34PM
Do you sell bigger boxes?
cavemen
Fri May 14 2010, 09:46PM
i got only one type
