  • Guests: 32
Billybobjoe (35)
07/19 Thomas (40)
07/19 VulcanBB18 (50)
07/20 rev (49)
Problems with Geiger-counter
hv-friekie
Thu May 13 2010, 11:39AM Print
hv-friekie Registered Member #2273 Joined: Thu Aug 06 2009, 07:02PM
Hey guys,
I am building a Geigercounter with this shematic:
Because I get bored of the tack-tack-tack in the speaker, i want to connect the Geigercounter to a counter decade with the cd4026. This device makes allready a great job.
But the problem is: Where do I connect the counter input to the geigercounter himself?
Do I need another device between them?
Best regards,
Philipp
Thu May 13 2010, 12:34PM
Hello Philip,
I would suggest using an AC-coupled Schmitt trigger to square up the pulses, and eliminate noise, before passing the conditioned data on to the next stage.
I have not been able to find 74315 in the LND catalogue, and wonder if an error has got in somewhere.
hv-friekie
Thu May 13 2010, 03:47PM
Hello,
I am not using the LND 74315 but this one here: Link2
It's fine for alpha radiation, it has a nice mica window.
And i think i fixed the problem: I hooked up the counter input to the collector of T1 in the schematic.
But i have some other Problem now.
When I use a 3 stage multiplier as in the schematic the speaker is klicking very fast, also without any radioactive source.
But with every klick the counter counts 1 higher.
When I scale down the multiplier to 2 stages I have one klick in about 8 seconds. (which is caused by the cosmic radiation i guess)
But the voltage at the output is to low for that the counter unit reacts.
I mean you can here a klick, but the counter don't counts.
Any ideas how to make the device more sensitive?
Best regards,
Philipp
Kilham
Thu May 13 2010, 04:31PM
Kilham Registered Member #2814 Joined: Wed Apr 21 2010, 12:28PM
Put a variable resistor in series with R1 to reduce and control the multiplier output. Do you know the output voltage at the moment?.
Thu May 13 2010, 04:42PM
hv-friekie wrote ...
The LND 712 recommended operating voltage is 500V, but your circuit diagram shows 1kV being fed to the anode. This over-voltage will produce uncontrolled avalanches, and continuous conduction which will damage the tube.
As for your counting problem, I have suggested that you condition the output pulse from the tube with a Schmitt trigger to make the pulses more compatible with digital circuits.
LND 712 is a miniature stainless steel tube designed for dosimetry and radiological protection - it has been made so that it will not be too sensitive and cause false alarms. The sensitivity of a GM tube depends, in part, on the volume of the gas it contains, and there isn't much gas in a 712 which has an effective length of 38.1mm and an effective diameter of 9.1mm. The bigger the tube, the more of it there is for particles and rays to hit.
