  • Guests: 57
Phototransistor circuit suggestions?
Killa-X
Wed May 12 2010, 09:14PM Print
Many to choose from, what is the best phototransistor and OP-amp design, for fiber optic SSTC modulation?
So far i tryed this circuit. However, on speaker the system sounded great, no issues at all. When i plugged it to my SSTC, i was getting a lot of RF issues...And I'm not sure what's the best method to prevent this. I've put a metal can around it and it was still picking up RF. My coil is running like it was in CW, because the LM741 or something, is picking up the coils resonance frequency.
For those who want to know, I'm using a halfbridge, Mini SSTC. In the past i had no issue, but i didnt need an amp for that IR switch. This phototransistor, needs the amp, which is causing issues :( Suggestions?
Killa-X
Mon May 17 2010, 12:35AM
Well, since i got no where far with this, I figured it would be better to go to the old style that worked for me in the past with no issues.
What type is best to get if I want to plug 5V in, and feed it to the UCC pin 3? These series have enough khz ratings for my use. I just need to know whats best...
Buffer totem pole
Inverted totem pole
Buffer open-collector
inverted open-collector
I was thinking of this one maybe, Schmitt Trigger style. I would like to get feedback. Last i connected a optoswitch to a SSTC, ucc pin 3, it sucked because it was NOT a pair. Link2
Also, Usually people use a 10ft fiber cable to connect a computer to a DRSSTC for audio. Is it safe to use these types of optoswitches? the 2 units are electrically separated...But physically connected. I was wondering if this can risk harm to my computer.
Mon May 17 2010, 05:16PM
I was connecting my sstc directly to the computer, without any kind of isolation cheesey I think if your driver circuit is grounded, nothing can happen to your PC.
Killa-X
Mon May 17 2010, 07:33PM
True, I'd just feel happier knowing it was safe. If I had a junk computer, I would, but all of my computers cost over 1.5K because they're gaming rigs. So I much rather not risk that, Dr. Kilovolt :) I think I'll just try the switch out, but use the buffer totem pole. This way when the LED is off, the logic output is low.
Tue May 18 2010, 10:54AM
You can probably get a junk computer for less than you could build an optoisolator.
I suggest an old laptop, connect your experiment to it, run it off batteries, and operate it with VNC over a wi-fi connection. Voila isolation.
Goodchild
Tue May 18 2010, 03:14PM
The best system ive use to date is the ST fiber RX and TX modules from OPTECH. The OPF2412T (RX) and the OPF1412T (TX) this system can be a bit pricey but I think that it's worth it the modules them self's cost about $10 each and the ST fiber cable is about $15 ( for like 10 feet) or so. They have all the amps built into the modules so you send TLL signal in one end and you get TLL out the other. The only thing is you have to take care to shield the models in a grounded metal box.
Hope this helps
ManiaC
Tue May 25 2010, 04:56PM
ManiaC Registered Member #2763 Joined: Sat Mar 27 2010, 11:48AM
I use a Analog Key (CD4066) and (PS2652) and its work good ...
Supplies are necessary , for the Analog Key and Optoisolator must be another isolatet supply.
something like that
