  • Guests: 31
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
building a modulation transformer with a mot?
Wed May 12 2010, 04:14PM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
Hi has anyone tried to build a mod. transformer? Could you build one with a mot? A mod. tras. is just a current mod, right? Anyone try using a magnetic amplifier as one?
Thanks,
Paul
radiotech
Wed May 12 2010, 05:32PM
Can you be more specific: What is the transformer modulating and what is driving it and what frequency response will the modulation have?
Magnetic amplifiers are modulators; Some modulate /50/60 Hz
(carrier) with a frequency response from DC to a few Hz.
This is a mag amp transformer that I grabbed when a old battery charging system was upgraded to solid state controls. Notice the big outer coil- (AC load winding) and the two differentially connected
DC control windings. Two cores are used
1273685573 2463 FT89046 Bampxfm
Wed May 12 2010, 05:49PM
the transformer is modulating a 1100 watt vttc. It's driving nothng, just liminting the current based on the audio unput to the mag amps cuntrol input. freq, few kiloherz-50 khz
Wed May 12 2010, 06:37PM
Why not buy an audio transformer? They are readily available and have a fairly large bandwidth.
Wed May 12 2010, 07:06PM
don't they cost a buldle? anywho, how you cheacked to tag to a 550 watt tras? Over a 1000! ( from stores)
Wed May 12 2010, 07:27PM
If this is for use with your 803 pentode, you could use screen grid modulation which requires less power and is more economical with parts than anode modulation.
Wed May 12 2010, 07:35PM
thank you
but do you have a example of screen modulation that I could use?
PS why does one of the members always call you Harry?
radiotech
Wed May 12 2010, 07:59PM
Screen modulation cannot fully modulate the carrier.
To try a MOT connect the filament winding to the output of 100 watt or so audio amp. Connect the HV secondary in series with the bottom end , (DC feed) of the TC) Connect a 1000 uufd/3000 volt cap across the HV secondary too.
screen modulation using a tube : >
1273694370 2463 FT89046 Scan0004
Wed May 12 2010, 08:02PM
but why only 100 watts? don't you need 1/2 the wattage input for 100% mod? how would the number of turns on the mot affect mod?
Wed May 12 2010, 08:12PM
803 wrote ...
just Google "screen grid modulation"
803 wrote ...
That's funny, I was just about to ask you why people kept on calling you Susan.
