  • Guests: 40
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
Circuit Help
hboy007
Mon May 10 2010, 04:55PM
I almost thought I fooled myself, but there we are. the 10µF cap of the charge pump defines the (maximum) charge transfer per cycle so it can be dimensioned to obtain a slightly negative voltage.
1273510532 1667 FT88885 Negvolt Addon
add ripple filtering as needed smile you can even beef things up by adding another charge pump and subsequently merge of the diodes to a fullwave bridge:
1273511292 1667 FT88885 Cp2
Matt Edwards
Mon May 10 2010, 05:41PM
Thank you Hboy007!
