  • Guests: 48
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Massive Fireball
cduma
Thu May 06 2010, 02:27PM Print
I have no idea where to put this thread since it is several topics
I want to create a massive fireball for Haunted Yard attraction for halloween.
My idea involves a compressed cylinder of air held back an electrically actuated butterfly valve with gas(or a very fine powder) on top and electrial ignition.
The basic idea is that ~200mS after the valve is opened the ignitor activates and WOOMPF!
Comments?
MinorityCarrier
Thu May 06 2010, 03:40PM
Look up "propane canon". The Hollywood effects version.
Hope you have good insurance for when you burn down part of your neighborhood during R&D. I'd expect you'll get a visit from men in dark suits and sunglasses also.
Hon1nbo
Thu May 06 2010, 06:46PM
MinorityCarrier wrote ...
that depends if it's for a private party or part of the public display and what state he's in wink
anyways, Propane is the standard, but if simplicity is key here, and you don't care about reloading after uses, you can use an air launched Alcohol. With all flame cannon designs gas or liquid, a little bit of flammable material can go a long way, so be conservative and for goodness' sake take care using it!
-Jimmy
MinorityCarrier
Fri May 07 2010, 12:39AM
After that moron's stunt in Times Square, anything having to do with propane fireballs is bound to attract the attention of The Man.
But seriously, I'd recommend that cduma talks to his local fire marshal. A 'controlled fireball' for entertainment purposes may be legal so long as he has some sort of official permit/prior demonstration approval. I used a big propane torch to burn weeds on my property when I lived in Idaho, but I had to get a Burn Permit first.
Fri May 07 2010, 12:56AM
Paranoia strikes deep
Into your life it will creep
It starts when you're always afraid
Step out of line, The Man come and take you away
We better stop, hey, what's that sound
Everybody look what's going down
Stop, hey, what's that sound
Stop, now, what's that sound
Stop, children, what's that sound
Buffalo Springfield - For What It's Worth
Hon1nbo
Fri May 07 2010, 01:40AM
it's not hard to get approval, as long as you allow them to inspect your setup, give them the time, burn conditions are good, etc - I got my local fire marshal's approval for a flame cannon based off of alcohol pretty easily, however you appear to be using it for a public display. This is a different matter, unless it is for a private party, because then there is an "audience" which means you are no longer doing a one off effect for yourself, but rather it is a Flame Special Effect requiring a license in many states. Depending on circumstances, you could get approval anyways but it isn't as easy. If the party is private, and there are under a certain amount of people present in proximity (in Texas it's 50) then you can get away with it if you conform to standard burn regulations. If it is public for say trick or treaters, then good luck.
-Jimmy
radiotech
Fri May 07 2010, 02:36AM
Propane has issues if released in the open and ignition fails. Could seep down and inside some space experiencing a draw draught and reach its LEL.
Fri May 07 2010, 10:20AM
Proud Mary wrote ...
ROFL
MinorityCarrier: Why do you need to burn weeds?
MinorityCarrier
Fri May 07 2010, 09:31PM
In Nampa Idaho I had 1.49 acres of land with an irrigation canal, wier, leaky headgates and a small spring. Weeds were a problem. Couldn't afford a lot of herbicide so I burned weeds to keep them from going to seed (also a pyromaniac, but that's another story).
Adam Munich
Mon Jul 05 2010, 06:25PM
Too big?
