  • Guests: 52
Deceitful Electronics
1 2 3 4  last
IntraWinding
Wed May 05 2010, 04:04PM Print
Just Stumbled this Link2
And it's on eBay, here for example Link2
What electronic cons have you seen?
Alan
IntraWinding
Fri May 07 2010, 10:35AM
Looks like electronics is is a generally deceit free zone then wink
KLH
Wed May 19 2010, 03:35PM
I do know of some common cases of electronic scams (particularly counterfeiting), but I am currently unable to point out any very specfic examples such as yours.
I did hear of several thousand "Toshiba" laptops being recalled; they were all fake and as a result failed to function properly.
Then, of course, there is the well-known counterfeit battery issue. I have encountered two fake batteries, one of which was for my cellphone and the other for a laptop. The cell phone battery overheated, while the laptop battery held nowhere near its stated capacity of 4800 mAh.
These are just a few minor examples that I know.
radiotech
Wed May 19 2010, 06:38PM
As an electricain, we are told of counterfeit house circuit breakers which is a bigtime scam. If a circuit breaker is made in a foreign country the temptation seems to be use the licensed casement to make breakers with inner critical parts that wont pass the tests needed for export to the countries with the applied certification labels.
Somehow these get into markets outside the country of manufacture.
Take a look at these two powerbars gotten in an enquirey
One was purchased in a city, the other in a small rural store
far from pesky inspectors
The knockoff uses an illegal mounting screw from ground bond, tiny
wire poor crimps and most of all no internal parts are certified..
But from the outside they look the same.
1274294286 2463 FT88676 Powerbars
Thu May 20 2010, 09:47AM
The entire high-end audio industry is a massive con, speaker cables in particular.
They want about $15k for this particular cable.
James Randi actually has a challenge out to audiophiles.
Having said this, some high-end audio gear looks amazing, it can be thought of as a piece of art that just happens to reproduce music as a side effect. But the suggestion that it sounds better than the cheap stuff is a little suspect.
Thu May 20 2010, 12:45PM
Yeah, look at those MONSTER cables! I still can't figure out how a inner dielectric material in their audio cables makes any difference whatsoever despite their claims.
Renesis
Thu May 20 2010, 01:34PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
Steve McConner wrote ...
Anyone remember the Wattgate 381? Link2
Some of the comments are absolutely hilarious.
IntraWinding
Thu May 20 2010, 01:41PM
Esoteric audio! Now you're talking!
Don't get me started!
That's a whole different level of deceit!
A couple of the worst extremes I remember are 'special' sticky labels and bottles of water. You put them on your speakers etc., even by the mains fuse box and the improvement in clarity will leave you breathless - well, the price certainly will!
Wattgate 381! Unbelievable. First time I've seen that one. Those comments must be from the sellers, they're just too bonkers to believe!
"My apartment was infected with bad electricity from a previous tenant. Clocks ran slow, radios picked up foreign stations, digital tape measures would only read out in "metric". After installing Wattgate 381's, everything's working fine now. Thanks, Wattgate!"
cheesey
ShawnLG
Thu May 20 2010, 03:28PM
Any type of electronic pest propeller is a scam. I had put one inside of my formicarium to see what would happen. It did nothing.
More scams:
quicksilver
Thu May 20 2010, 04:39PM
I worked in now defunct speaker manufacturing firm in North Hollywood California (Vega) and "scam" in the audio world is a by-line for normal. The amount of ideas that were stolen from young guys going to school were so common, it was expected.
The slogan for that company was "Loud is beautiful, if it's clean". How do you determine if it's clean? What is clean enough? "Loud"??? (is beautiful?) This was back in the 1970's.
The crap that went on can still get my blood pressure up.. The entire high-end audio industry is a shameless scam!
1 2 3 4  last
