  • Guests: 59
two feed back coils in a vttc?
Sat May 01 2010, 08:30PM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
have two tubes that arn't mached, could i use 2 feed bacck coils in stead of tapping on of them? I think that would be better,
Thanks,
Paul
Sat May 01 2010, 10:24PM
I would advice on tapping, as the difference on two tubes would never exceed maybe 2 to 3 windings...
Sun May 02 2010, 12:54AM
I know that, but would it work? Is there any problems withe the 2 feed back idea?
Thanks,
Paul
Sun May 02 2010, 09:39AM
803 wrote ...
Thanks,
Paul
I matched my two random 811A tubes with a tapped feedback coil, at 21 and 22 windings.
I would say that the only problem is one feedback having a higher coupling to the primary/secondary and simple space, you could get close to your top terminal with so many coils.
Mon May 03 2010, 07:14PM
yes but could you put on coil on top of the other with a lawer of teflon between?
