  • Guests: 56
forced air cooling in a vttc?
Sat May 01 2010, 05:30PM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
Hi i was wondering, if you blow air on one side of a large tube ( 9 in long, 3 in wide) will that create heat stress and crack the tube because of the heat difference on the sides of the tube?
( i am using a hair dryer fan.
Sat May 01 2010, 07:31PM
I have had no problems with my 811A VTTC being forced air cooled from the side, you can see the construction here: Link2
Sat May 01 2010, 08:54PM
Actually, the air will stay close to the tube all the way around the tube thanks to Bernoulli's principles.
I've worked on high power transmitters with many 833's tubes and they were all fan cooled.
