  • Guests: 40
I am thinking of my own solid state Tesla Coil
cavemen
Fri Apr 30 2010, 03:29AM Print
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
I am working on three projects at once.
The project number one is the electronic control for the CNC machine.
I want to build a Tesla Coil that would use rectified 120VAC. A frequency generator will excite the secondary coil with a primary coil.
To know when the true resonance of the coil is, the machine would go through a range of frequencies, and than refine it until it decides that the coil is driven at resonance.
As I understand, the primary coil current consumption will increase when the coil is driven at resonance. Correct me if i am wrong.
So my powerful solid-state driven generator will be controlled by the chip.
If I am a novice in embedding and I want to solve this problem of tuning with an algorithm programed into the chip, WHAT IS THE EASIEST to program and MOST FIT FOR THE PURPOSE CHIP that I should use in my project? I would also like to know the numeric value of the frequency I am working with.
Can one chip do all the work or is it more efficient to use dedicated frequency generator, coder for the number display and the main microcontroller to tell what frequency to produce, take values in and display the frequency?
1272598185 2008 FT0 1 Approach
1272598185 2008 FT0 2 Approach
Fri Apr 30 2010, 01:16PM
Sounds like a cool design. On the feedback, you're probably better off going with something along the lines of current feedback. With this type of tuning, you don't need any type of digital processing and its almost failsafe. Just look at some of the current feedback schemes that others have used for their DRSSTCs and SSTCs.
Kipmans
Fri Apr 30 2010, 03:34PM
Kipmans Registered Member #91 Joined: Thu Feb 09 2006, 03:03PM
A DSP-controlled TC would be pretty awesome though.
cavemen
Sat May 01 2010, 05:51AM
Any PIC controller that can do the job?
The reason why I am asking is because I am thinking of buying parts and building a programmer. I want it to be fairly universal for anything I build.
I am a total novice to the subject but I am sure that I will get it in the near future, as soon as I decide what I want to build.
I wonder if some eight-legged creature from the PIC family has enough processing power to take statistics.
I had built a Mozzilini flyback driver, technically a SSTC. It uses two mosfets to excite a flyback from a TV.
Those thins are great.
Now I want to use innovation, make a device that can use 120V rectified to drive the priamry to make the primary more compact and power semiconductors smaller.
The primary will be printed right on the board with all the circuitry.
I want the device to tell me the resonance frequency of the secondary.
Sounds futuristic? Well I am just talking, but I need to get started.
Turkey9
Sat May 01 2010, 07:20AM
I don't think a flat primary works very well with a SSTC. As I understand it, you need a lot better coupling.
As far as the PIC, if you get one with a PWM module, I'm sure you could get it to work as it has feedback and bridge drivers built in. You'll still need the driver chips to provide enough current, but the PIC will generate the signals. At 8 or 20 MHz it'll be fast enough as the Fres of your secondary would most likely be in the 100-300kHz range.
Sat May 01 2010, 11:14AM
cavemen wrote ...
If you're going the PIC route, forget about just a programmer.
Get the ICD-U64 from CCS. Its a low-cost In-Circuit USB connected Debugger / Programmer thats only $75.00. And also get one of the CSS PIC C Compilers. They have different options to fit any budget.
wylie
Sat May 01 2010, 03:31PM
wylie Registered Member #882 Joined: Sat Jul 07 2007, 04:32AM
I'd be more concerned about the price of a PCB big enough to have usefully-large-enough traces for that primary. How wide would those traces have to be? Seems simpler and cheaper to use wire IMO. Coupling isn't going to matter if the primary-traces get blown off the board on 1st-light wink
What's your target power level?
cavemen
Sun May 02 2010, 01:56AM
it isn't important how the primary would look like
all i want you to suggest me is a good PIC to use in my project
Are there any 18 pin PICs that have the processing power to "tune" the requency following some program of going through the range of frequencies and finding the one that gives out the most <correct me if i am wrong> resistance?
The chip should also give out a numeric value for the frequency and send it to LSD screen through a decoder.
