  • Guests: 57
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Zarc - Now DRSSTC - UPDATED: 03/03/2011
MRacerxdl
Tue Apr 27 2010, 06:32AM Print
Well, I am continuing my project DRSSTC, named for Zarc.
Now its a DRSSTC Running with IRG4PC50U :D
Few pics of the project
Circuit design preview:
Coil preview:
Dissasembled toroid:
Test build:
More images in: Link2
Results in DRSSTC mode:
Used a fullbridge of IRFP250N with a 141nF 3200V primary cap, running at 100us tOn, 750W input. Yeah I know, I over pushing the limit of the IRFP250N, and without a OCD... I dont know why it is surviving, but I ran the coil even for 10min without any heat at the mosfets. I Think its the first DRSSTC with IRFP250N.
The Bus voltage is about 150V, and 2000uF 400V eletrolytic cap.
UPDATED: 17/05/2010
I finished the build, but I wont make it work at DRSSTC mode because I have no IGBT's, and I will make another DRSSTC with mosfets, not that one...
Pics of the assembly:
Soon, sparks in SSTC mode :D
UPDATED: 03/03/2011
IGBTS at DRSSTC: IRG4PC50U
140A Primary Peak Current
80cm Sparks to air
Audio Modulated:
Link2 <-- Playing Lady Gaga - Telephone
Link2 <-- Playing Evanescence - Bring me To Life
Link2 <--- Playing Coldplay - The Scientist
Soon, new base for Zarc DRSSTC
MRacerxdl
Mon May 10 2010, 01:39AM
Updated: 09/05/2010
Turkey9
Tue May 11 2010, 02:56AM
Wow that's a great job with those MOSFETs. You can easily blow them on a simple ZVS driver. Good job on the streamer length!
Tue May 11 2010, 08:22AM
This is interesting :)
I am looking forward to reading more about your MOSFET adventure in DRSSTC duty, what is your driver like?
MRacerxdl
Tue May 11 2010, 11:16PM
Thanks! I will test other mosfets in the place of IRFP250N, I thinking about using IRFP460 because the 500V Voltage cap, but I dont know if it will handle it. I will try.
I am using a normal SSTC circuit, 74HC14 -> 74HC08(with interrupter) -> TC4429
The only thing, its that my interrupter is for DRSSTC with 100us tOn and variable tOff. Soon I will finish my coil build, and test other mosfets like IRFP260 and 460.
MRacerxdl
Mon May 17 2010, 05:48AM
Updated: 17/05/2010
kilovolt
Sun May 23 2010, 06:48AM
kilovolt Registered Member #2018 Joined: Tue Mar 10 2009, 09:56AM
Nice coil, nice results, good work wink
Best regards
kilovolt
MRacerxdl
Thu Mar 03 2011, 05:01AM
Zarc DRSSTC Updated, Added Audio Modulated Videos and are in IGBT :D
Coronafix
Thu Mar 03 2011, 06:07AM
MRacerxdl wrote ...
Way to kill a great song. sad
Thu Mar 03 2011, 09:28AM
That looks like a very nice coil!
What are you using for the interrupter/audio modulation?
