  • Guests: 61
Simple flyback driver Help please!
quicksilver
Sun May 02 2010, 02:14PM
Antonio: thank you, I appreciate your time & input.
Niykon: I believe that is a SS NST from the pic and am unfamiliar with the usefulness of it's place in that application. There may be some protections in place that are at issue. Whats more it's input looks like AC mains wiring to me. Are you SURE it is built for low current/voltage input ???
Because of copper prices, SS NST's have been around for a bit and they may get messed up from moisture, impact, etc. The best thing to do is get a 10+ M ohm high wattage resister and make a little high voltage probe (use a damn cheap little analog meter) & see if it's even putting out energy.
Niykon
Mon May 03 2010, 09:04AM
Niykon Registered Member #2826 Joined: Sun Apr 25 2010, 08:21PM
quicksilver wrote ...
Im sure it is. The input is listed right on the side of it as 12vDC
quicksilver
Mon May 03 2010, 01:57PM
There was a company that made neon transformers for automobiles in addition to mains activated NST's. If it's NOT dysfunctional then the level of current may be too low.
The quickest way to tell without opening it up is check if you're getting anything at all. If not then see if you CAN open it and start tracing from the input leads to the first component they hit (perhaps a smoothing cap(s)).
But you have a 3 lead input; assuming the blk & red are the DC the white lead may be a switching element. In copy machine (& similar) there are HV units which demand the integration of the switching lead into the input for them to light up with HV.
teravolt
Mon May 03 2010, 07:30PM
Niykon the best circuit for flybacks is a Mazzilli circuit.
try Uzzor web page for the circuit
the moast important part is the pollypropalene cap ,say 1-2 uf and fast diodes. Try 1n5408's to try it because they are common and pausibly fast enough. You can parallel flybacks if they are exactly the same. I've not found any flyback circuit that is sapirior.
quicksilver
Tue May 04 2010, 01:53PM
Niykon: Before you chuck the ss NST try connecting the Blk & Wht lead together, using that as DC negative and red DC positive and then see if she lights up.
Th3_uN1Qu3
Sat May 08 2010, 03:36PM
Th3_uN1Qu3 Registered Member #2614 Joined: Sat Jan 09 2010, 08:57AM
My experience is that self-oscillating drivers such as the single 2N3055 one aren't appropriate for this application.
The 555 driver is decent enough so try that. Look for "Eirik's 555 driver basic", i did that one and it gave good results. It can sustain an arc of about 3cm and spark to 7cm with a flyback from a 17" monitor, 4 turns primary and an IRF630 mosfet. I have run it up to 1 hour continuously and i haven't fried the transistor yet, but it's on a BIG heatsink (the heatsink came from the monitor too, it was used to cool all the power transistors).
Btw the reason why the spark distance is quite a bit longer than the arc is because the monitor flyback is half-wave rectified internally so you're getting quite a bit of DC. To sustain an arc you need AC. I wanted to make a plasma tweeter but with input to pin 5 of the 555 sound was very low and i was too lazy to figure out how to make a separate amp to drive it, so for now i have abandoned the experiment. It does an awesome job at lighting up old fluorescent tubes though.
