  • Guests: 42
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Solid State NST
cduma
Sat Apr 24 2010, 04:15PM Print
I recently aquired a 12VDC to 2KVAC ~30KHz at 10mA with an open voltage of 3KVAC. I want to try and use it to make an itty bitty TC.
My question is how would it handle resonant operation?
Sat Apr 24 2010, 04:32PM
I have used a rectified 4kVAC 20mA 20kHz SMPS NST for a little marx generator, I remember it as running pretty unstable.
cduma
Sat Apr 24 2010, 05:25PM
I will probably make one of those too
cduma
Wed Apr 28 2010, 02:59PM
This forum seems kind of dead...
Any more input would be nice! I dont want to break my new toy by making it resonate.
Wed Apr 28 2010, 03:28PM
I never killed slash damaged it, it would just at times act up weird and seemed to shut down.
dmg
Wed Apr 28 2010, 10:25PM
Mads Barnkob wrote ...
hmm... does that have an in build GFCI?
cduma
Wed Apr 28 2010, 10:55PM
I highly doubt that mine has it built in since I have let it arc to everything except for the battery or input wires. Although the other guy displays the symptoms.
dmg
Thu Apr 29 2010, 05:13PM
Well, you can always disable the GFCI in the NST. then It should not mysteriously turn off whenever you run it.
Thu Apr 29 2010, 05:36PM
gatedbreakdown wrote ...
The SSNSTs I have are all potted in a block of varnish or resin, I can draw arcs without a problem, but my best guess is that its overcurrent / overvoltage protection kicks in when it experiences transients. Mine run straight from 230VAC, designed for neon tubes.
Herr Zapp
Thu Apr 29 2010, 07:34PM
gatedbreakdown -
The GFCI you suggest "disabling" is only present in a conventional AC-powered, iron-core NST, not the solid-state, DC powered, high-frequency power supply this thread seems to be discussing.
Regards,
Herr Zapp
