  • Guests: 95
Optical regenerator?
Sat Apr 24 2010, 12:25PM Print
Hi all.
OK try not to laugh but...
To get Gen >0 tubes is crazy expensive these days because everyone is using them for night fishing/rabbiting/etc...
so why not use a gen 0 tube, have a small B/W camera taking an image of the output window and then take the data and feed it back to the input window via an IR diode+LCD setup ?
the basic plan is that even if there is horrible feedback this can be dampened down to achieve a "super regeneration" effect that shows an image of particles etc for not much money.
/me scuttles off to the Patent Office...
-A
Sat Apr 24 2010, 12:46PM
What about one of these, Andre:
I have one and it runs just fine.
Sat Apr 24 2010, 12:50PM
Or you could wait a bit and receive my gen1 tube . . . Have one broken one and one fully working as spares
radiotech
Mon Apr 26 2010, 06:39AM
Regenerating feeble images with the hope of achieving a critical point sensitivity may connect you with that purported to be detected by the third eye, which if we had it, would be in the center of our forehead.
I believe the transcommunication crowd used to use video feedback as you suggest.
Mon Apr 26 2010, 03:16PM
Video feedback loops have been used as fractal generators.
Many PMTs can be configured to have gains of 10E6 - the order of magnitude needed for single photon counting.
The chief problem with small signal detection is not amplification at any scale, but ensuring that the SNR remains workable. The signal must be extracted from the noise floor, and resolved into useful data proportional to the magnitude of the detected particle's energy, which implies linear amplification.
Mon Apr 26 2010, 05:36PM
For amateur astronomy (another pastime of mine) there are many examples on the web of 'hacked' webcams, some of which have excellent sensors. e.g. Link2
Basically the exposure time is as long as required, and to reduce noise the voltage is reduced and the onboard amplifier is disabled whilst the light is being gathered.
Then if multiple similar pictures are taken a program such as Registax can minimise noise, hot pixels etc.).
I haven't tried 'hacking' but judging from the photo's, the setup must be pretty light sensitive.
Then you need a good (f#) lens sytem.
For Gen0 why not just use IR LEDs,
Regenerative amplification sounds unlikely to give stable results,
Signal processing of consecutive video frames is probably a cheap option.
You could do your regeneration in software too.
(AtoD converters can be chosen that have a wider dynamic range than optical sensors)
Tue Apr 27 2010, 09:33AM
Proud Mary wrote ...
Or, in layman's language, You can't polish a turd. (No matter how much DSP you throw at it.)
This is a lesson I learnt the hard way in my last job, developing DSP algorithms for laser spectroscopy. I spent weeks trying to filter out ripples in one signal, and eventually I gave up and started beating on the optics guys to get rid of them for me. They knocked them down by 20dB in an afternoon by swapping a regular piece of glass for a wedged piece, and the instrument finally performed to spec.
