  • Guests: 40
Question about off line disruptive Tesla coils.
Tue Apr 20 2010, 09:42PM Print
As many know, the primary on a typical OLTC is very thick and one or two turns. If you use IGBT's that do not each have high enough current carrying capabilities, you can use two primaries, two tank caps, and an IGBT to switch each of the two tank circuits.
My question is, what is the best way to make two identical primaries? You can wind one on top of the other like Steve Conner Link2 , and you can wind one primary outside of the other. But which of those is better? With the differing size or height in relation to the primary, the coupling would be slightly different. Is this too minuscule to affect anything? I guess if it was a big deal, you could twist the primary wires together...
So it is just a question of how much coupling matters.
Coronafix
Wed Apr 21 2010, 12:36AM
If you used flat copper strip you could wind one on top of the other starting half a turn apart and have them symmetical.
How big is the coil estimated to be?
Wed Apr 21 2010, 10:07AM
I think you can also just use a single primary and whack all the IGBTs in parallel.
I used a single tank cap, only the primary is split.
Wed Apr 21 2010, 05:08PM
I would use Steve's single cap/multi-winding scheme,
you could also have single winding/multi-cap for the same effect,
but if you have multi-cap and multi-winding you are making multiple tuned circuits/resonators,
if the resonant frequency of two of them differs by 1% for example
(capacitor tolerance, winding differences etc.)
then before the 50th cycle, things will die!
(5% resonant frequency mis-match would begin to get bad after 5 cycles)
The mutual coupling of multiple resonators would give me maths nightmares!
Mon Apr 26 2010, 04:31PM
I meant to say single cap bank and multiple primaries O_O. Wow, that was quite a mess-up on my part cheesey
At Steve Connz0r, how bad would you expect the current sharing to be with the IGBT's simply paralleled? What would be the best way of overcoming this? I am sure the current involved in this type of circuit does nothing but complicate things.
Either way, i will go with a dual thick litz primary.
