  • Guests: 66
Homemade Flyback secondary
radhoo
Sat Apr 17 2010, 11:27AM Print
Here are some of my results on building a flyback secondary. 0.4mm CuEm wire/7layers/400turns, Green House foil as insulator and a BIG ferrite core.
150x150
Video:
Construction details:
Sat Apr 17 2010, 01:01PM
Oh, nice! :)
i did wonder if one could wind a secondary using thin mylar from a capacitor as insulation?
Shapelock does also work but isn't a brilliant insulator.
-A
Sat Apr 17 2010, 03:12PM
Somewhere in 4HV, as I remember, are details from a German experimenter who had but 100t. on his secondary, and produced quite creditable sparks, to the surprise of many.
The term flyback transformer is perhaps a misnomer, since it is really more of a choke, a disruptive dV/dT device rather than the turns ratio affair of the true transformer.
It is not uncommon in GM counter designs to find the tube HT generated across a small single-winding choke, which is quite satisfactory when only a few tens of uA are required.
Turkey9
Sat Apr 17 2010, 09:14PM
Clear packing tape worked for me. Two layers of tape between layers of winding. Something like 20 layers of winding with a spark output of about 2cm from a ZVS driver. Sealed the ends with hot glue and it holds up great.
Yours looks great! Really good contruction.
radhoo
Sun Apr 18 2010, 09:39AM
thank you all for your comments.
Sun Apr 18 2010, 10:51AM
a vacuum pump is handy if you want reliability- otherwise air can form corona which eats the insulation for breakfast.
a modified bicycle pump can be enough though.
-A
cjk2
Sun Apr 18 2010, 03:52PM
Back in ancient times, I did something like this. I had maybe 500 turns of 28AWG on a large and old core. I ran a ZVS driver from about 90v from a modified MOT (had two MOT primaries on it to provide isolation). Here is what I got:
1271605960 51 FT87624 Arc1 Upload
1271605960 51 FT87624 Dsc00913
Killa-X
Sun Apr 18 2010, 08:28PM
Nice flyback. I did 200 turns on min and used nothing but paper for insulation (oil dunked it) and it runs fine :) Just like pole pigs, I used paper soaked in mineral oil :D
radhoo
Sun Apr 18 2010, 09:31PM
@Conundrum I have a refrigerator compressor that I can use, but I don't plan to use this flyback that often so the risk to loose the insulation is small.
@cjk2 those sure are some monster sparks. Interesting ZVS primary winding, can you provide more details?
@Killa-X sounds like an easy way. Could you post a few pictures?
