  • Guests: 49
VTTC Tube
ManiaC
Sat Apr 17 2010, 08:46AM Print
ManiaC Registered Member #2763 Joined: Sat Mar 27 2010, 11:48AM
Hallo
I got a question
hmm
This tube will be good for VTTC ?
RS1054L PDF
111tubecopy
I think to run it with a 1 line of My Neon sign transformer (4000V)
Tabliczkaznamionowa
Sat Apr 17 2010, 01:03PM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
yes i think it would be good. the only thing is is you connect the screen to plate like some people, then thats not good because the screen is rated to 900v. but then again lots of people over drive their tubes
Sat Apr 17 2010, 01:53PM
You will have to be more careful with ceramic tubes as you do not have the visual warning of red plates as in a glass tube.
radiotech
Sat Apr 17 2010, 04:39PM
The construction of the filament transformer could be interesting. A really heavy duty soldering gun or two could be used to get the secondary close to the tube.
Do you intend to get the tube to act as an oscillator in a system powered by the NST? If so, you could experiment with reduced filament voltage and see what happens.
