  • Guests: 47
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
tetrode in a vttc
Fri Apr 16 2010, 08:34PM Print
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
Hi,
this is my first post and i'm almost done with my 803 350 watt coil. i just need one more thing, how to wire the 803. it is a pentode but i've tied the screen grids together to make a tetrode. so my question is how do i connect the screen grid ? do i connect it to ground with a resistor, connect all the grids, or sonthing that i havent thought of yet? here is the link to the data sheet Link2 also the input is a 2kv voltage multiplier if that helps.
Thanks,
Paul
