  • Guests: 48
overpriced gdt?
dingo27
Thu Apr 15 2010, 07:31PM Print
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Hi, i want to buy some ferrite GDT, i chose
EPCOS B64290-L40-X830
Ferit toroid R58 AL5400nH N30
but i can have it for 11,4€ ONE, which is somewhere around 15$
for example, i could have
TN20/10-3E25 Toroidal ferrite core TN, material 3E25, 5340nH
for just 1,7€, but i must take 10 (which looks like only choice)
is epcos really more expensive than ferroxcube?
This is from 2 different part resellers. How much cost some good GDT in US?
Thanks for response!
mmt
Thu Apr 15 2010, 08:19PM
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
Personally i would never buy such a expensive core, as for replacment i am using cores from toroidical EMI line filters, it's not the best way but these works just great for me. But of course if u wanna quality core especially designed for HF its good thing to invest in this component. wink
cjk2
Thu Apr 15 2010, 11:02PM
$15 is crazy for one core. An American company called electronics goldmine sells nice cores for about $0.25 each. See if electronics goldmine will ship to you. Also try amadon. Farnel might also sell cores that you could use. If all else fails, you can take apart a computer power supply and use the small E cores for your GDT.
Fri Apr 16 2010, 05:07AM
Almost all ac line common mode filters
(the type with identical windings for each phase)
are of MnZn ferrite so perfect for a GDT up to 100's of kHz.
Typical Al would be several uH per turn-squared.
It doesn't matter which particular MnZn ferrite you use.
With very few exceptions any large ferrite toroid that you find will be MnZn.
NiZn ferrite has MUCH lower permeability than MnZn, at least 10x less
but they are useful to the highest sstc frequencies practical.
So just get any ferrite toroids that are of a suitable size and wind your gdt.
As above, put a capacitor in parallel or series and measure the resonant frequency to determine actual inductance if you wish.
Knowing the core size, number of turns and inductance you can look for a similar core to determine the ferrite type.
You will probably not find an exact match as MnZn ferrite permeability varies significantly with flux density and temperature, just use a near approximation +/- 50%
