  • Guests: 56
Secondary winding turns
raff
Thu Apr 15 2010, 09:35AM Print
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
hi guys,
from properly built tesla coils out there, I almost always see them secondaries done with 900 - 1000 turns...
my QUESTION:
why? smile
cant I go for , say 1500Turns?
another example: 3.2"D x 18"L with awg#34 magnet wire (more than 1500 Turns) .... is this BAD?
Thu Apr 15 2010, 10:18AM
It all depends on the geometry and peak currents in a coil. With a very long length of thin wire the resistance of the wire itself starts to limit the output of the coil. So it all depends on coil geometry and the wire thickness. As far as I know there isn't an exact calculation for this at this time. Usually going by feel works out well enough wink
Thu Apr 15 2010, 10:30AM
Because 899 is too little and 1001 is too much! tongue
I've always recommended using as many turns as you can, with the finest wire you can handle, for small SSTCs. It lowers the resonant frequency and makes the whole thing more noob-friendly.
My old OLTC2 coil had 1700 turns, but that was probably a little too much. Why? In simple terms: A transformer that steps voltage up must also step current down. If you use too many turns, the output voltage will be very high, but the current will be too low to feed big sparks.
Steve Ward's big DRSSTCs had a lot of turns, one had 2300, and he could get sparks over 10 feet from them.
Thu Apr 15 2010, 10:46AM
Also with too much turns, heating of the wire becomes a problem, especially at higher powers.
raff
Thu Apr 15 2010, 11:19AM
thanks for the inputs! cheesey
Thu Apr 15 2010, 02:47PM
As Richard Hull once said, never get caught up on the numbers. Just build your coil and wind away.
