  • Guests: 71
Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
Ceramic doorknob caps construction
Electroholic
Mon May 01 2006, 01:10AM Print
Ok, I just blew up a ceramic cap, but it is kinda strange as I can't find any metal inside?
where are the parallel plates?
1146445644 191 FT0 Picture 001
1146445644 191 FT0 Picture 002
Sorry for the bad quality, the Pix were taken with my ir mod webcam.
Dr. Shark
Mon May 01 2006, 10:17AM
I always ment to saw apart a doorknob to see how it is constructed, now you save me the trouble! Could you smash the remaining bigger piece a bit further to see how it is constructed internally? I would not be surprised if there were no actual plates, but the metal was sputtered directly onto the ceramic substrate.
Electroholic
Mon May 01 2006, 02:33PM
and so I smashed it.
The construction is pretty simple actually.
Just a ceramic shell, picture it as two coffee mug glued back to back.
the both "inner surface of the mugs" are coated with some conductive material(plates).
Looks exactly like the surface of those piezo speaker.
then a spring loaded electrode clip is press fitted.
but before that, a thick piece of wax paper is put in to protect the plates.
The first pic is one electrode with the waxed paper removed, the bottom of the HexNut is pretty sharp.
thats why I am guessing the waxed paper is for protection/ or corona?
It arced thru the dielectric, as you can see in the pic.
1146492702 191 FT8736 Picture 001
Oh, and the ratings of this cap is 1000pf 5kv.
[Edit: Go here Link2 to learn how to post pictures.]
Self Defenestrate
Mon May 01 2006, 09:34PM
Self Defenestrate Registered Member #87 Joined: Thu Feb 09 2006, 01:36PM
Nice drawing there. It definetly is silver.
Dr. Shark
Thu May 04 2006, 10:12AM
I wonder if there are any fun things one could do with the strontium titanate or wahtever it is, now that you have got it out of there. I suppose it could be piezoelectric or even pyroelectric. Be careful grinding it up though, strontium is possibliy toxic I think.
I am surprised how low the dielectic strength is, 1kV / mm is worse than air, I would have guessed it is at least 10 times that! I think I need to do some stress testing with some of my doorknobs.
Electroholic
Thu May 04 2006, 10:34AM
rolleyes It was my bad, lol, and according to Wiki, they have a dielectric strength of 8Mv/M,
so 5mm is 40kV.
I was running them way over their spec, continuously in a mini SGTC.
My old SG was badly designed, and this cap actually sparked over the surface a few times.
you can probebly see the trace on the first pic.
I sanded it down a little bit, put ~5 layers scotch tape around it, and it works perfectly again.
Until I decided to use my ZVS driven flyback instead of a wimpy 12W 5kv SS NST.
They get HOT within minutes.
I was thinking about putting them under oil, but I guess its too late now.
One thing I don't understand is that, when i try to calculate the capacitance of it, using the dimentions.
I don't know how to do the cylindrical part, so I only calculated the area of the parallel circular plates.
If C was indeed 1000pF, I would need ~4000 dielectric constant, which is nothin close to 1200 as stated on Wiki.
Can anybody Help me out? My Phy and Calc are not that good.
Dr. Shark
Tue May 09 2006, 09:48AM
Yeah, I think these ceramics are tough little critters, capable of standing much more voltage that what's on the label.
Regarding the capacitance, the parallel plate formula ignore any part of the electric field that is "buldging out" between the plates, which might be a very significant amount for these small plates. So I think you are within a realistic range.
Fusion
Thu May 11 2006, 09:02AM
Fusion Registered Member #354 Joined: Thu Mar 30 2006, 10:12AM
C=Eo*Er*area/thickness (measured in metres), E0=8.85e-12
So if you have a 1m2 capacitor, Er=233 and thickness=1mm, you have
C=2uF. If area=2m2, you have 4uF
If 40kv/mm is true, you can have 412 Kjoule/m3 ¡great!
It is possible make AC caps with strontium titanate?
