  • Guests: 33
DRsstc electronics being weird
lightlinked
Tue Apr 13 2010, 10:12AM Print
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
I was messing with the coil and my tungsten breakout point fell off (its goes on the topload with a magnet) and broke in half, so i put it back on thinking it was all good, it probably doesn't need to be pointy, and boom, a flash of light from the base blowing up the control logic and my panel meter. i replaced all the logic chips but now it doesn't want to make nice sparks. So now i'm turning to you guys for some insight.
it is based off the feed back and logic part of Steve's driver just with big driver chips
one of the apparent problems is that it doesn't want to do its thing during all of the on time. i replaced all the diodes between the CT and inverter chip but that isn't it.
top is signal to one of the gate drivers
bottom is feed back CT
1271152949 2087 FT0 Dsc 0773
here is a weird thing, the inverter looks like it isn't doing what its supposed to
top is CT feed back
bottom is H bridge output at around 24 volts
1271152949 2087 FT0 Dsc 0836
here is half of the bridge's GDT signal, is the sine action at the beginning normal?
1271152949 2087 FT0 Dsc 0841
i am temporarily solving my scope problems by borrowing one, my school lets you check out lab stuff, fun times. these digital scopes are a whole new world. my computer doesn't have a serial port so i have to literally screen shot it
Goodchild
Tue Apr 13 2010, 02:30PM
umm in the first scope SS the output of the CT looks way wronge it should look just like a nice primary current ringup maybe something is wronge with your CT? I have had many many problems with CTs in the past.
It should look a little more like this
4494008209 3d387aefd0 O
Tue Apr 13 2010, 04:52PM
First thing, is what do you mean by "big" driver chips?
Some of the high current gate drivers, such as 15A IXYS drivers, have UVLO lock-out built in. So if you're Vcc inside the chip droops, the chip will shutdown. This can be remedied by proper bypassing and layout.
I suspect your issues are probably bad layout and bypassing of the high current gate drivers, assume you are using something more exotic than the typical TC442x or UCC3732x commonly used.
Tue Apr 13 2010, 09:24PM
Make a 50% duty oscillator about the freq of your secondary with 5v output, and feed that into the circuit. then separately test every individual circuit on the board. That always helps me!
lightlinked
Wed Apr 14 2010, 06:01AM
i'm using 4 TC4421 chips. upon further probing it appears that one or two of them on one side might have died.
update:
i replaced them and now it works again. for now...
thanks for all the suggestions
Wed Apr 14 2010, 12:26PM
Oh, those aren't big driver chips and they should be fine for your application. Just make sure you have them properly bypassed. I use a 0.1uF ceramic (closest), and a 10uF tantalum (NOT electrolytic) for bypass on the 9A drivers i use.
