  • Guests: 44
GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
Wanted, 942 series film caps, electrolytic caps
cjk2
Fri Apr 09 2010, 05:47PM Print
For my DRSSTC project, I need some capacitors. I need at least 5 of the 942 series caps that everyone uses (the 0.15uf 3kv variety) and a pair of largish 200v electrolytic caps of at least 4000uf, they will be in series in a voltage doubler. Low ESR and ESL preferred.
Does anyone have caps like these that they would be willing to sell?
Fri Apr 09 2010, 07:31PM
I could part with 6 of the .15uf 2kv variety, and i have 2 brand new 11,000uf 250v 39A rms CDE caps i could part with. It would be nice to have some money to put into my drsstc project, as of now it is a $0 budget project wink. I also have a 1.4kvdc 10uf used big*** film cap, if you need a snubber. The leads are very short though, but you can replace it with buss bars anyway.
Let me know what voltage and capacitance you expect to make your cap bank, i may have something else you could use.
cjk2
Fri Apr 09 2010, 09:18PM
Great! How large are the big 11,000uf caps? How much for all of the items you listed?
Sat Apr 10 2010, 01:32AM
These caps are quite large. They are 3 by 5 5/8 inches.
Well, the CDE film caps are 45 bucks each, and these CDE lytics are about 400 dollars. smile
But seriously, just PM me an offer. What do you think the lytics are worth? cheesey. The terminals are depressingly small, but they are low ESR (18mOhms). You can get the datasheet here: Link2 Scroll to the very bottom, on the right. Decide if they are worth anything to you, if not i can still sell the tank caps.
What is your cap bank capacitance?
Sun Apr 11 2010, 02:27AM
I don't know if these will work for you
High voltage/current polypropylene capacitors. 0.47uf, and each handle 11A of ripple current. 2000vdc, 630vac
I use these for my induction heater and they are quite robust.
I have 20 of them.
lpfthings
Tue Apr 13 2010, 01:11PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Whats the difference between the 940C and the 942C series? If not much, you can buy them for quite cheap from Link2 :)
Tue Apr 13 2010, 03:50PM
lpfthings wrote ...
The 940C series tends to fail at the connection from the foil to the lead. They are in Terry Blake's 'good and bad cap' list. It is under the 'bad' capacitors. They work fine for things like sstc DC blocking caps and are good for about any other circuit that is not high pulsed current.
Luca
Tue Apr 13 2010, 08:41PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Arcstarter wrote ...
lpfthings wrote ...
The 942C series has higher rated limits but I think that as long as you respect the rated limits (peak and rms current, voltage) the 940C series should work as well...
Probably the 942 series is also more tollerant to over current/stress...
Luca
Wolfram
Wed Apr 14 2010, 09:19AM
lpfthings wrote ...
The 940Cs are fine for DRSSTC work, and much better value for money than 942Cs. Finn Hammer used 940Cs in his Thumper coil if I am not mistaken, and I've never heard of them failing in DRSSTC duty due to overcurrent. What does kill capacitors in DRSSTCs though is overvoltage, and Steve Ward lost a 942C MMC due to overvoltage a few years ago. For a given price you can get a higher voltage rated MMC with 940Cs compared to 942Cs, essentially making it much tougher.
Sorry for the rant, but I hear 942Cs recommended for big DRSSTCs all the time, and while they are one of the few caps that work with SGTCs, the situation is different with DRSSTCs. This is especially true with big DRSSTCs, a coil I am designing requires a 1µF MMC that can handle 5kV RMS. If I built this with the common 942C20P15Ks, it would end up with 670 caps; 10 in series to get the required 5kV RMS rating (500V per cap) and then 67 strings in parallel to get the required capacitance. This bank would have a peak current rating of almost 30 kiloamps, where it would never even see more than two kiloamps in practice, and an RMS current rating of over 900 amps, where it would hardly see a sixth of this in practice. This would of course make for a very durable MMC that would essentially last forever. The problem is, it would also make for a very expensive MMC, costing over two thousand US dollars at the current pricing on these caps from Richardson Electronics. I can imagine it would be quite bulky and impractical too, not to mention the work it would take to build an MMC with almost 700 capacitors.
The best approach is to find out what sort of voltages and currents the capacitors will see, and then find the cheapest alternative that satisfies those requirements, not just taking the capacitors which turn out to be ideal for SGTC use, throw enough of them in series that they don't die immediately in use, but live a very short life, and then enough strings in parallel to get enough capacitance. Using other capacitors, for example 940Cs, I can make an MMC for my coil for a quarter of the price, and I would never even exceed the datasheet ratings of the caps.
Sure, you can exceed the datasheet ratings, that's the name of the game here, but I think the best way to do it is to balance it out, not just exceed the voltage rating by a huge amount, while staying well within the current rating. That's the way you'll get the most reliable MMC for a given budget.
Nothing personally against the 942Cs, they have been shown time and time again to be the best caps for SGTCs, I just don't think they are the right solution for medium to big DRSSTCs, though for small DRSSTCs, they might make some sense.
A.M.
Wed Apr 14 2010, 12:50PM
I also think the 940 series are fine. The failure mode is high peak current blowing the metallization off the film, and DRSSTCs have better control over peak current than SGTCs.
I've been running a bank of some random yellow caps for quite a long tme now.
