  • Guests: 36
Three phase AC power.
Chris Cristini
Mon Apr 05 2010, 08:20PM Print
Can I make my three phase generator in to a single phase generator with no rectifier? I did allot of searching on Google and here and found nothing my plan is to make a small four stroke engine run off of hydrogen for a generator and use a portion of the power for the electrolysis. Oh I did find a way with a transformer having a center taped primary and single wind secondary.
radiotech
Tue Apr 06 2010, 07:24AM
Why dont you describe your three phase generator. Is it a car alternator?
Your website does not lead me to anything relevant to the thread.
3l3ctrici7y
Tue Apr 06 2010, 09:16AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
The only way I know of (given your constraints) is to just use one of the three phases as your single phase output. It can probably produce a bit over 1/3 of the total output from that single phase (because the other two are not dissipating heat)
Transformers cannot to phase conversion.
Tue Apr 06 2010, 12:13PM
Unless the laws of physics have changed recently,
even if you use ALL of the alternator power for electrolysis it will not be enough to run the motor continuously.
Why not use a three-phase rectifier to produce the DC for electrolysis?
As above, just use any two of the three 'phase' wires for single-phase ac output - if required.
Chris Cristini
Tue Apr 06 2010, 02:16PM
Yea sorry guys I pretty much had a huge brain fart and realized that its not happening without a three phase rectifier
radiotech
Tue Apr 06 2010, 08:55PM
A three phase rectifier will yield the most DC power for electrolysis, but should be rewound to match the voltage/current requirements of the gas cell.
Hugh homopolar dynamos were used for electrolysis at about 8 volts and the use of 6 volt auto generators were popular with home electroplaters once.
Tue Apr 06 2010, 09:31PM
OR measure the dc output of the alternator/rectifier
and use an appropriate number of electrolysis cells in series.
Chris Cristini
Wed Apr 07 2010, 01:12PM
It is a brush less motor from a big copier and it puts out 13A 26V @ 1200RPM when it is shorted across the shunt resistor it takes allot to turn which is good right meaning it does not waist to much? It is allot smaller than an alternator. Oh that is only two out of the three wires.
Russell Haley
Thu Apr 15 2010, 05:00AM
Russell Haley Registered Member #2478 Joined: Mon Nov 23 2009, 03:24AM
Hmm, a perpetual motion machine. We don't like your kind here.
radiotech
Thu Apr 15 2010, 05:51AM
Your motor data : When you turn it at 2600 RPM, with no load attached, What is the voltage across three pairs of terminals; t1-t2, t2-t3,t3-t1. When you have that voltage, (and frequency if you can get it) Connect a variable load across all 3 pairs, (3 resistors) and adjust the resistance until the open circuit voltage drops by 50%.
Now calculate the total power in the load for the maximum resistance load power your motor/generator will produce.
If you short it out and turn the shaft by applying a heavy torque, you could demagnetize the rotor, if it turns out to be a hight torque stepper motor. You might find this out by applying a light load and turning the shaft to feel how many cog steps it makes in a revolution.
Stepper motors have Zero breakdown torque.
