  • Guests: 47
Will this 555 flyback flyback driver work?
spectral532
Sun Apr 04 2010, 02:00AM Print
spectral532 Registered Member #2725 Joined: Tue Mar 09 2010, 02:31AM
After burning out my single transistor driver, I decided to try building a 555 driver for my flyback. I found this schematic online which doesn't seem too complicated.
ZWgB5
Has anyone had experience using this driver? I noticed that the primary coil in this circuit is connected straight from Vin to Ground. How will the 555 waveform reach the primary?
[Edit: Image size]
Antonio
Sun Apr 04 2010, 03:08AM
Obviously wrong schematic. The ground of the power supply is at the other end of the big capacitor. It's usual to put a capacitor (100 nF) between pin 5 and ground (pin 1) of the 555. FET and primary turns not specified.
TechNerd
Wed Apr 14 2010, 08:25PM
TechNerd Registered Member #2289 Joined: Thu Aug 13 2009, 02:49PM
why don't you just use the scematic given in the 555 datasheet... http://www.datasheetcatalog.org/datasheet/fairchild/NE555.pdf
TechNerd
Wed Apr 14 2010, 08:31PM
there is something wrong with the link try this.
