  • Guests: 65
self-oscillating Boost converter
Chris Cristini
Sat Apr 03 2010, 05:09PM Print
self-oscillating Boost converter can it be done with no I.C's?
ScotchTapeLord
Sat Apr 03 2010, 06:51PM
I imagine that since a LOPT is an isolated form of boost converter, yes it is possible. You can probably take most self-oscillating flyback drivers, and with a little tweaking, use them for a boost converter.
Just switch out the gapped ferrite transformer with the inductor+diode+capacitor combination of a boost converter, and determine the best choice for a feedback winding experimentally, perhaps clamping its output so as to improve the gate drive.
Even with that design, though, I'd be tempted to stick some sort of IC in there...
cjk2
Sat Apr 03 2010, 07:10PM
Yes, I did this to make a joule thief type circuit. build an astable two transistor circuit, then use one side of it to feed the base of your boost convert switch.
here are a few ways to do it:
Here
and here
Sat Apr 03 2010, 08:11PM
The original Joule Thief actually is a self-oscillating boost converter with one transistor. So yes it can be done.
Chris Cristini
Mon Apr 05 2010, 08:08PM
Thanks guys!!!!
