  • Guests: 52
very large voltage magnification in a DC resonant design?
Crunchy Frog
Fri Apr 02 2010, 03:19PM Print
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
I've noticed that when simulating a dc resonant coil at low C and high L (around 10nF and 15H) the peak voltage ends up being much greater than 2x the input. (it says it should be 2x on Link2 From basic electrical equations, it should be v = 2pifLI. But when I put in the numbers from the simulator, it doesn't work (I solved for frequency and it comes out too high). The voltages the simulator comes up with also vary a great deal.
So my guess is that something odd is happening to the frequency the inductor sees. Is this plausible?
Also, how much should I trust the simulator's results?
EDIT: Never mind. As usual I found the solution right after posting. It was because a significant current built up in the charging inductor while the gap was conducting.
radiotech
Mon Apr 05 2010, 04:37PM
The AC voltage across any inductor is IXl. So could you get 6.28E^6
from a 1 H inductor at 1 amp operatting at 1 mHz?
In a calculation yes, but inductors we know about have physical
limits.
