  • Guests: 37
Topload opinion
Killa-X
Tue Mar 30 2010, 03:04AM Print
Sorry for the large picture for the people that don't have fast internet. I wanted to get peoples opinions on my topload. Originally for my SSTC, Will it be suite enough for a DRSSTC? Does it look like it's big enough? Currently, with the topload, JavaTC predicted 105khz isn't too bad...I have a skinny coil because I think they look better than the fat ones (my opinion).
So, What do you guys think? Should i keep this topload, or does it look too small. If too small, suggestions? Thanks!!!
(For fun i did camera settings to yellow tint the image) due to lighting to reduce glare on the topload.
Secondary = 4.5 x 28" of 30awg
Topload Minor diameter 4" (A)
Major Diameter 18.5" (B)
|A|
|----B------|
Dr. Slack
Tue Mar 30 2010, 07:10AM
The aluminiumy-looking one looks fine, but you might experience corona from the top turns with the small cylindrical one.
Hang on a minute, I think there *is* a beverage called "Corona" which comes in that sort of top load!
Killa-X
Tue Mar 30 2010, 07:06PM
Dr. Slack wrote ...
oh you miss understood..Shouldn't have set that there. The soda can isn't a topload. Just the green coil, My SGTC just happens to be there. Recently i read online that having a topload VERY close to the secondary (3mm space between the two) acts like a short, thus making a weak power output. I never knew this and my coils (as seen on the red one) is VERY SHORT. So I guess I need to lift them a few inches!
