  • Guests: 73
Capacity of a ducting toroid
Mon Mar 29 2010, 07:07AM Print
Hi All
I have begun the construction of my first large toroid for a DRSSTC and would like to build it in a manner like this: Link2
With a different wooden frame system, but this still leaves me to wonder how its capacitance is if its filled and taped over with aluminium tape, will it then have the capacitance according to its new surface or will electrons also be charged at the surface underneath so I will infact have a higher capacitance than the original ducting would have?
If I were to calculate with rippled ducting instead of a smooth toroid in javatc, would a figure of 2/3 larger surface area be a good measure?
Luca
Mon Mar 29 2010, 07:40AM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Mads Barnkob wrote ...
NO, electrons occupy only external surfaces. To calculate toroid capacitance just use the standard formula (or javaTC), the approximation will be very good regardless the kind of surface (corrugated or smooth).
Regards,
Luca
dmg
Mon Mar 29 2010, 03:29PM
edit: err... my bad, didn't read that carefully, never mind this
