  • Guests: 19
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Min pulse width to trigger SCR
MinorityCarrier
Mon Mar 29 2010, 04:28AM
You are correct with the current, you can go a bit lower if you are concerned about blowing the gate junction.
I don't know if the capacitance you are referring to is the gate-cathode PN junction capacitance, but its usually a good idea to have a resistor between gate and cathode to prevent DV/DT charging of the gate, so your drive circuitry would be looking at a parallel RC load.
Mon Mar 29 2010, 10:42AM
I didn't know what "compliance voltage" of a SCR was, and I defer to MinorityCarrier because he actually makes semiconductors for a living, and I mostly just wreck them for a living.
Besides I'm too busy b-slapping Patrick for posting on here while drunk.
Wed Mar 31 2010, 11:33AM
if you are simultaneously triggering SCRs then you should use a shockley diode or a DIAC to ensure simultaneous trigger right?
Wed Mar 31 2010, 12:57PM
No. I don't even remember what a Shockley diode is.
SCRs aren't guaranteed to work in parallel, no matter how you drive the gates. If one triggers early, then it can rob the anode voltage from the others and they may never trigger at all. I've seen railgunners parallel up SCRs, but it's one of these "At your own risk" things. Just because it worked for some guy once, doesn't mean it'll work for you. Maybe a fast risetime for the gate pulse will help, but a diac or tunnel diode isn't the only way to achieve that.
I assume here we're talking about the situation where the SCRs are in "parallel" as far as their gate circuits are concerned, but as far as the anode/cathode circuit is concerned, they're in series or independent, as you often see in a controlled rectifier. That works fine, and all you need are the ballast resistors to ensure that one gate doesn't hog all the drive.
Some power electronics textbooks say that you should steer gate pulses away from any SCRs that have reverse voltage on them, but in the controlled rectifiers I've built, I just drive all the SCRs all the time and have got away with it.
Thu Apr 01 2010, 08:28AM
A DIAC is two Shockley diodes facing opposite directions, it's the same as a DIAC but you can't do AC stuff
