  • Guests: 68
08/24 voltek (49)
08/24 DJ Cosmo (17)
08/24 n8 (39)
'Triangular Cellulation'
Avalanche
Sat Apr 29 2006, 09:05AM Print
A small SSTC I started building last night smile
Specs :
fRes - Estimated to be about 6-700Khz
Driver - PLL
Output Stage - Halfbridge of IRF840s (hmm)
Secondary former - 2 1/4" rainwater pipe
Base etc made out of MDF - routered, sealed, smoothed and spray painted
Hoping to get first light very soon, then will be adding an interrupter, and eventually making it into a mini DRSSTC, when I find a source of IGBTs.
1146301519 103 FT0 Triangular
Wilson
Sat Apr 29 2006, 12:02PM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
Thats cool! A very neat and clean setup. I hope you all the best of luck with first light smile
Avalanche
Thu May 25 2006, 07:42PM
Thanks,
I have finally got around to completing the coil, I made a new half bridge from 2xIRFP460s
The fRes is over 1Mhz afterall, about 1.5Mhz, due to the heavy gauge wire on the secondary.
I've made a video anyway, pictures coming soon. In the video the coil is running from 110V into the half bridge, and is half-wave rectified.
2.2MB, MPEG1 Format. Enjoy!
Edit: There is a picture here. This shows the coil but with the old halfbridge.
Thu May 25 2006, 10:25PM
looks good cheesey
The streamers look alot like my vttc (probably becuase I used alost exactly the same secondary), although I am guessing that you are getting considerably higher efficiency... Mine was drawing about 15 amps amazed
Thu May 25 2006, 10:26PM
Excellent, very nice. I like the nice geometric shape of the base!
ragnar
Thu May 25 2006, 11:26PM
That's just adorable, Avalanche!
Always love the neatness/finished product of your coils - mine are never portable... they always remain as alligator clips and generally spread out over most of my desk =P
Avalanche
Thu May 25 2006, 11:35PM
Thanks for the comments
Yeah I tend to spend a bit longer building things into complete finished articles now, my lash up projects from the past used to just get dismantled and I had nothing to show for all the time I spent neutral
In the video I am running it from a fairly small 2:1 step down transformer, so it is current limited somewhat as well. Maybe running about 75 watts at a guess. I will be trying it on the 230v mains directly, but unfortunately this is the point at which my coils usually explode! Fortunately the MOSFETs are easy to replace, and I will probably drop some IGBTs in soon and add an interrupter/tank cap. That will be when I make my next order, until then it remains an SSTC.
A couple of recent pics, showing the new half bridge. This is how the coil is at the moment (note the sticker!)
Last 2 pics - My new halfbridge design, and the secondary coil base.
Edit: Webpage is now up, visit my site to find it (link in sig)
1148599654 103 FT8642 Tri2
1148599654 103 FT8642 Tri3
1148599882 103 FT8642 Tri Bridge
1148599882 103 FT8642 Base Tri
