  • Guests: 49
Tonic (38)
earth3 (29)
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Radioactive Mineral Sample Prospecting Equipment - Advice Sought
Sun Mar 28 2010, 10:30PM
I know that Les has had some very good results prospecting with his rig, but if I was starting from scratch, I think I would construct a minimalist set-up, with a geiger head mounted on an arm, - as with mine and metal detectors - to sweep the ground at a few inches.
This would be the ideal set-up for searching out uraniferous pebbles, as at Littleham Cove, and the beaches around St. Austell. The gamma signal from even weak emitters would show up with great clarity with this sweeping method.
One of the longer Russian metal-skinned tubes would give the detecting head a degree of robustness necessary to the task.
The circuit modules would consist of nothing more than an HT supply for the tube, and an audio amplifier of good headphone strength - two or three transistors.
I wouldn't bother with a meter, or any battery-hogging extras, since the specimens, once located, can be taken away and studied in more detail on the bench.
The mixed silicates of uranium and vanadium at the Cove sound very intesting to me, and very worthwhile to find them, though I don't imagine they will have the same weight-for-weight activity as the best Cornish pitchblende.
IntraWinding
Sun Mar 28 2010, 11:39PM
This seems to be the one to go for:
SMB-20 Link2
Mon Mar 29 2010, 11:13AM
IntraWinding wrote ...
SMB-20 Link2
Give me a few days to make some comparisons for you.
IntraWinding
Mon Mar 29 2010, 11:15AM
Thanks for that. There's only good data on that model that I can find, or at least, read!
There are also two distinct SMB-20 models.
One has dull, and one bright red insulators.
I'm guessing the bright red's are newer.
plazmatron
Mon Mar 29 2010, 01:42PM
Proud Mary wrote ...
This is very true. One of the problems I had, especially with a geiger tube, was maintaining a reasonably short distance between the tube and the area under survey.
It is easy to miss good samples out in the field.
An old metal detector, would make an ideal mount for a geiger counter in an application such as this.
Les
Mon Mar 29 2010, 06:37PM
Have a look at this one:
I've bought a number of items from Denys over the last year or so, and not had any problems with him.
IntraWinding
Mon Mar 29 2010, 10:15PM
plazmatron wrote ...
An old metal detector, would make an ideal mount for a Geiger counter in an application such as this.
Les
Thanks. I've been thinking of copying a metal detector, but using an old one's a good idea. I imagine it will frighten the locals/tourists less too wink
Whilst searching for any details about your rig, Plazmatron/Les, I've put together a handy set of links to related articles in this forum. Handy for me, anyway wink
Plazmatron/Les: is it just a cd-v700 that you use?. It's all I spotted searching your site + this forum.:
Things to do with "hot rocks" Link2
Making a Geiger-Müller Counter Link2
Pitchblende Uranium Ore Link2 (Sale and Trade)
Pitchblende Uranium ore samples for sale! Get em while they`re hot ! Link2 (Sale and Trade)
Anyone else collect Fiestaware?? Link2
Russian Geiger-Mueller Detector Link2
Geiger counter circuits Link2
Americium 241 fluorescence Link2
Radiation counter (Geiger) tubes Link2 (Sale and Trade)
Geiger tube supply? Link2
Geiger counter Link2
SBM 21 geiger tube datasheet Link2
Leaching uranium ore Link2
Alan
IntraWinding
Mon Mar 29 2010, 10:46PM
Thanks! I somehow missed the ruler in that shot.
CI-21G / SI-21G : With the help of Photoshop it looks to be about 250mm x 19mm.
I see Denys has one slightly more expensive tube:
STS-6 / CTC-6 Link2 No ruler, but it looks slightly smaller.
I've asked if he can send me data on both...
I'd just been looking at the CI-22 but that's only 215 x 18 Link2
Alan
Mon Mar 29 2010, 11:16PM
Don't worry about Cyrillic data sheets - nine times out of ten it's easy enough to work out what they're on about from the values of the parameters.
plazmatron
Tue Mar 30 2010, 01:08AM
Yes it is. However, it is modified to accept different probes, (specifically Scintillator probes). The original tubes for these have only a small detector area, as they were designed for post nuclear war surveys!
The only reason I picked the CD-V700 for the field, was its ruggedness, and the fact that many hobbyists have sites detailing modifications for it.
Obviously, in the lab, I use more sensitive/better suited instruments.
Les
