  • Guests: 56
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Interrupting SSTCs with TC4421/22
kiat
Wed Mar 24 2010, 10:17AM Print
kiat Registered Member #2115 Joined: Fri May 08 2009, 01:17PM
Hello,
I want to interrupt an SSTC with a 555 independently variable circuit. The SSTC uses antenna feedback with 74HC14, and its design is mainly from Steve Ward's SSTC5.
I have only used the UCC37322/21 gate driver chips before, so I don't know how to interrupt without the "Enable" pin. So far, I can only think of 3 ways to do so:
Directly tie the feedback and 555 outputs together.
Make the 555 output drive a MOSFET in series with the 5v supply to the 74HC14.
Make the 555 output drive a MOSFET in series with the 74HC14 output signal.
Can I ask, if there is any other way to do so, and which method of interrupting the signal is best?
Thank you,
Kiat
Wed Mar 24 2010, 11:30AM
1269430236 95 FT86329 Sgrhjdtrd Jrfhr
Curtis
Wed Mar 24 2010, 04:10PM
Curtis Registered Member #883 Joined: Sat Jul 07 2007, 01:02PM
You could also use AND gates in series with the driver chips but i think without the TI chips you might need a free running "startup" oscillator. The inverting TI chip automatically sends out a short pulse when enabled, negating the need for a startup oscillator.
WertWiktor
Wed Mar 24 2010, 06:26PM
WertWiktor Registered Member #2671 Joined: Mon Feb 01 2010, 09:47PM
here U have SSTC5 with tc442* Link2
but dont use this bridge from the scheme (the parts are too weak to handle this)
Curtis
Wed Mar 24 2010, 07:27PM
Why all the inverters in series. That would just add a lot of delay.
WertWiktor
Thu Mar 25 2010, 04:03PM
Yeah, this guy did his tesla when Steve Ward don't publicate finalized project ...
The most important thing is this bc107 transistor ;)
Thu Mar 25 2010, 05:49PM
Curtis wrote ...
The delay is not going to hurt you. If your only switching at say 300kHz (3333ns period), then (4) extra gates (44ns), is nothing. If you were switching at 10MHz, then that would be a different story.
ManiaC
Sat Mar 27 2010, 12:03PM
ManiaC Registered Member #2763 Joined: Sat Mar 27 2010, 11:48AM
I make that and it work
126943023695ft86329sgrh
today i make some picture ...
(sorry for my bad English) neutral
kiat
Mon Mar 29 2010, 05:11AM
Thank you all for the informative replies. So I have chosed to interrupt it by putting a bc107 transistor at the output of the 555 disable signal, and connect it to the antenna signal.
Thank you a lot
kiat
ManiaC
Mon Mar 29 2010, 08:20PM
Hallo
Picture of driver & interruptor
My SSTC runing on 120V (video)
