  • Guests: 49
What to do with these?
ScotchTapeLord
Tue Mar 23 2010, 06:32AM Print
I have these brick IGBT modules that are around the same size as the CM300 dual IGBT brick, maybe slightly larger, but they are single IGBTs. I have two of them.
I'm considering using one for some kind of boost circuit power supply and the other for some kind of single switch tesla coil driver, maybe OLTC. I've wondered how low frequency you can go with a class E driver, as they are typically for high frequency, but my amateur eyes can't see why one couldn't use the topology with frequencies below 100kHz.... But then where are all the brick class E coils? ;)
Perhaps there's something better I can do with these mysterious single bricks? (I think I read that they were 400A somewhere...)
Tue Mar 23 2010, 06:43AM
Ive been wanting to snag some of those cm300's for a rail gun HV smps. like the M-16-A4 with the tri-burst feature, a rail gun with a 3 slug burst in rapid succesion would be nice around the apartment, for downing russian fighter/bomber aircraft cheesey
Link2 and even better video ... Link2
Z28Fistergod
Wed Mar 24 2010, 10:20PM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
*would also like to see electromagnetic ADA*
