  • Guests: 57
Conducting thread and SiC
Sat Mar 20 2010, 01:18PM Print
Hi all.
Finally got around to trying this experiment, and it works well.
the basic plan is loop the conducting thread across the crystal for multiple glowing points, then secure with superglue+baking soda (UV adhesive would also work here) and when everything looks ok epoxy over the top. voila, homemade LED.
Sucky brightness but it works and is stable at 36V@35mA max and lights fine off 9V with just the thread as series resistance.
the forward and reverse voltages differ by about 0.15V so its behaving as an LED in parallel with a resistor it seems.
maybe someone has a use?
-A
1269091127 96 FT0 Siliconcarbide
1269091127 96 FT0 Silicon2
1269091127 96 FT0 Silicon3
rp181
Sat Mar 20 2010, 03:58PM
I think results would be better in a vacuum, closer contact and bubble free epoxy.
Sun Mar 21 2010, 03:06AM
If Rp181 is right, go tear a compressor out of a 'fridge and get a Bell jar wink
IntraWinding
Sun Mar 21 2010, 07:51AM
Nice. Could you get an area glowing?
What's that superglue+baking soda mix?
Sun Mar 21 2010, 01:32PM
cyano with baking soda carefully sprinkled to force the glue to set ultra quick.
The model 'plane crowd love it, as it costs pence and sets like concrete. Oh and did I mention that it is a fairly good insulator?
-A
"Bother" said Pooh, as his Airtel dongle dropped signal again...
IntraWinding
Sun Mar 21 2010, 03:57PM
Thanks. I somehow missed that one - another trick stored away in my brain smile
