  • Guests: 34
Conical VS flat pancake primary
raff
Sat Mar 20 2010, 08:46AM Print
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
hi guys,
I have tried(and tested) with 5 turns conical primary (6" diameter 0.3" spacing) ..... wouldnt I strain the IGBTs if I where to go 5 turns also with 0.3" spacing FLAT pancake primary?
-Ralph
Goodchild
Sat Mar 20 2010, 03:37PM
I use a .125 spacing flat primary on my DR and it works great, even when pumping out 4 footers. I originally had a helical primary and it flashed over a lot angry
In my opinion the flat primary is the way to go.
raff
Sat Mar 20 2010, 11:25PM
ok... will do some simulation later as to w/c (conical or flat) has more inductance... if flat has lesser, then adding more turns will do...
