  • Guests: 59
Found some iggys! :-D
Sat Mar 20 2010, 05:40AM Print
Hey guys.
One day i got bored and wanted some time alone, with none of the noises i am always fed up with, such as crying baby, guitar, bass guitar, and yelling. So, i went to take a walk. I started walking further and further, and i ended up on a street right outside of the city limits. Was about 2 miles from home. Well, i had once been on that street and noticed an abandoned trailer kind of thing. Once i went in it, out of curiosity (not well hidden from the very busy street, i stay safe!).
Well, this time i went into an abandoned city bus (extremely old!) that was behind it. This place has been abandoned for many years, the most recent thing i could find was from 1998. I kept looking around. This bus, along with the trailer, are full of useless rusted car parts. Suddenly, i found an 'ignition box'. I suppose it just contains some snubbing caps and a transistor and junk like that. One that i got has an external mounted transistor in the TO-3 package. It is far too old to read any numbers.
Anyway, this was the place i found my first iggy, which was an HEI coil. Knowing i would find more, i looked around. I ended up finding 2 fairly intact distributors with the HEI ignition coil mounted on it, and 4 'typical' ignition coils, as well as a smaller kind that is much older, that i have never seen before.
I picked them all up and found a bucket with a dang ~14 gauge steel handle to put them in. I picked up 3 of the ignition controllers or whatever they are called too. Weighed about 30 pounds, so i walked the couple miles home.
I tested them all to a very high voltage, enough to arc over the HV stand off neck continuously, with sparks starting at about 1.5 inches with a repitition rate of a few tens of Hz, i supposeth. Only one was dead, which was the least expected one... It was one of the HEI's, it has an open primary. That is a project for another day, possibly reviving it by giving it a new primary in some very ghetto way.
Well, her is a pick of the group (with the dead HEI off to the side), and a picture of the odd coil. You cannot see i am sure, but the top plastic part is dry rotten and it has cracks all over the place. The HV was arcing through all of them, it looked pretty cool.
1269063616 1225 FT0 Iggys 001
1269063616 1225 FT0 Iggys 002
HazzWold 1993
Mon Mar 22 2010, 05:59AM
Nice find
Mon Mar 22 2010, 05:01PM
Hehe, i found 2 more HEI coils, and another in the can.
This would make a crazy bank of iggys, if i paralleled all the can types i have. That is 6 iggys tongue.
Now only if i had a good driver...
quicksilver
Mon Mar 22 2010, 08:54PM
Arcstarter:
Got a question for you....
* What about a small NST (rectified if need be)? They are oil filled. If steps were taken to prevent the arc from crawling all over aside from where you wanted it - why would you even need a driver other than a break-point-type relay or a SCR/555 type circuit? I was thinking of a bug-zapper - 2Kv - just something with enough voltage to make the step up from a series of 3 coils, etc
