  • Guests: 50
The Radar Kilovolter - a dangerous contraption
Tue Mar 16 2010, 09:24PM Print
The Radar Kilovolter is a spark-gap voltmeter that has nothing to do with Radar, but Kilovolter would be quite approprate if spelled Kill-0-Volter.
I bought it on ebay for a pound, about NOK 9.
The rough re-cycled cardboard box has the texture of egg cartons, and tells us that it came from the post-war rationing era, the years of so-called
'National Austerity,' 1947, or 1948 perhaps. UK television broadcasts had stopped in 1939 for fear that the Germans would use the VHF signals
to home in their bombers, and was not re-started until 1946. The service was again suspended in 1947 due to a national fuel crisis, so there were
very few trained TV repair men, and very little specialist TV servicing equipment that technicians could afford. The Radar Kilovolter
spark-gap voltmeter was launched into this impoverished market, and must have been responsible for numerous electric shocks.
As you can see, the knob on the end is first set to 30kV, the probe is then placed on the high voltage source,
and the black wire is attached to the Earth. The knob is then turned, reducing the gap, until a spark jumps between the
spheres, when the voltage is read off from the position of the cursor on the scale. The cursor runs along a rail and is moved by
a thin cord, in the manner of the radio wavelength scales of the period.
The outer skin is made from thin, bendy celluloid, and turning the knob while holding the probe tip
on the high voltage source must have been memorable experience... smile
1268774543 543 FT0 Kilovolter399
MinorityCarrier
Tue Mar 16 2010, 11:03PM
Dangerous, though it still does have a certain charm.
Thanks for sharing.
Wed Mar 17 2010, 08:07AM
Actually pretty accurate if enclosed and containing controlled atmosphere.
the sphere trick is a well known method of determining spark length, and if atmospheric pressure and temperature is known (assume humidity is zero if using silica gel in air path)
is pretty good.
-A
ragnar
Wed Mar 17 2010, 08:13PM
Proud Mary wrote ...
That's hilarious! Surely responsible for many bites, I wonder what serious market penetration it ever had... cheesey
GeordieBoy
Wed Mar 17 2010, 08:26PM
Probably popular with the undertaking profession if no-body else wink
