  • Guests: 69
Night vision hacks
Sat Mar 13 2010, 06:31PM Print
hmm..
seems a bit bulky but might work for what i need it for (low level x-ray imager)
might be handy for detecting the weak gamma rays from Am241 or Th232 (over a long time it could build up an image if the output window is installed onto a large cooled CCD sensor)
Anyone else tried this?
also am after a tube obviously :)
regards, -A
"(*"!U$(*!" said Pooh, as he launched his TV into next week due to football ownage...
Bjørn
Sat Mar 13 2010, 07:09PM
See here Link2 and here Link2
EEYORE
Sat Mar 13 2010, 07:13PM
One of our members here, Plazmatron, has already successfully made a radiation viewer with three night vision tubes stacked together. I bought one from him and am VERY pleased with its performance as well as the price. (Much cheaper than buying three from the source listed)
You can see gamma radiation from uranium rocks and x-rays from a tube. (Functions terrifically as a fluoroscope!).
Matt
Tue Mar 16 2010, 05:45AM
Seems interesting. Does anyone know of a source of image intensifier tubes for those who live in the USA?
MinorityCarrier
Tue Mar 16 2010, 03:29PM
Google Gen-1, Gen-2 or Gen-3 tubes or night vision tubes.
Wed Mar 17 2010, 07:40AM
i have it on good authority that the Gen 0 and 1 tubes are often dumped when they are upgraded to Gen 2+.
maybe check out the army&navy surplus?
note. If they are missing a lead but otherwise look intact buy them anyway, as this can often be patched up with conductive epoxy and/or low melt 59c alloy.
i also discovered a kludge of bicycle repair cement + graphite powder :)
if they query the use, mention their application for examining electronics stuff and they might let you buy one. Don't mention radiation though smile
EDIT:- interestingly the very early self adhesive luminous signs using ZnS:Mg (reacts to red laser pointer) might be useable if backlit using infrared pulse during the camera's flyback period to dampen the persistence.
Maybe combine with an IR filtered webcam or underclocked CMOS camera to make a poor man's fluoroscope?
regards, -A
MinorityCarrier
Mon Mar 22 2010, 05:52AM
I finally got around to arranging a test of a Gen-3 night vision headset with a 7uC Ra226 gamma source.
I could not 'see' the gamma source even when it was held right in front of the Gen-3 apreture in a very dark room. I could not detect with any degree of perception any increase in scintillation with the possible (remote) of a few extra 'bright pinpont flashes'.
My direct observation results in my opinion that gen-3 night vision tubes don't detect moderate level gamma radiation very well, if at all.
EEYORE
Mon Mar 22 2010, 06:42AM
MinorityCarrier wrote ...
You need scintillation material to see. smile
Some x-ray image intensifier screen should work. This is how the fluoroscopes that Plazmatron sells work.
Matt
Mon Mar 22 2010, 08:50AM
heh...
apparently they use disposable film in old x-ray film modules, so maybe you can obtain one from a helpful dentist or vet?
they throw them away after each use for safety reasons.
also expired films have perfectly good scintillators :)
-A
MinorityCarrier
Mon Mar 22 2010, 02:58PM
The way I read the posts it seemed that it was suggested the night vision tubes would detect gamma directly.
I have a 6199-PMT scintillator probe (Victoreen) and a (damaged) KI crystal that I have played with in the past with regards to scintillation detecting.
