  • Guests: 76
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Marx generator project problem
empdude
Thu Mar 11 2010, 08:41PM Print
empdude Registered Member #2732 Joined: Thu Mar 11 2010, 07:48PM
Hey all,
We are a team of students making a Marx generator as part of a project. We are using 4 kV caps and 1 Mohm resistors and our classic generator currently has 8 stages. We are currently experiencing a few problems with the distance needed to generate sparks and the voltage along the generator. The only way we can have a spark, usually only the first spark gap, is if the two ends are extremely close ( the sparks are barely visible). The other thing we noticed is that there is a significant drop in voltage along the generator (50% or more). The input voltage is currently only 500V, but from what we understand we should still be able to make the generator function. Surely when we move on to a higher input voltage sparks would come more easily, but wold like to make sure our circuit is configured for optimal performance and not just compensate for losses with more voltage. The only thing we could think of that could explain the problems we are having is that perhaps the resistors are not the right value for our needs.
Any tips you could give us would be greatly appreciated.
Thu Mar 11 2010, 08:59PM
For smooth large-radius spark gap electrodes (not 'pointy') allow 3kV per mm.
At 500 V you will need a very small gap.
When the spark gap 'fires' allow about 300 V drop. In a Marx generator with tens of kV per stage it's not a problem, with 500 V per stage you're lucky to get any final output.
Go straight to 4 kV to see better performance.
I believe that the uv from one 'firing' gap will help to 'fire' the next, so try to put your spark gaps in line to benefit from this effect.
Hon1nbo
Thu Mar 11 2010, 11:26PM
the trick to a marx generator, in my experience, is twofold: one, tune your first gap, two: have enough voltage between the first two stages such that the voltage of the two capacitors now in series from the first gap firing will easily exceed the voltage necessary to fire the second gap
as 500V you are really lucky to get anything at all, as even with the first gap closed that only leaves 1kV for the second gap, so it too will have to be very small
go increase the input voltage
quicksilver
Fri Mar 12 2010, 12:27AM
A guy once showed me a "trick" that piggy-backs on this discussion. He would use a long delicate needle nose pliers to first curl the ends of the leads prior to soldering and the consistency of the curl allowed a very close, consistent gap.
