  • Guests: 49
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
First sstc Going Class-E
Corey
Tue Mar 09 2010, 09:15PM Print
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
Just finished winding the secondary it's approx 518 turns (7 3/16") of 28 gauge wire on a 3.5" dia form. Resonates at around 780khz. Coil is not coated yet, waiting to get some clear gloss poly. Pics wink
First one is the driver board with antenna feedback
Th 1268168301
Th 1268168300
Th 1268168299
Th 1268168298
Tue Mar 09 2010, 11:06PM
Thats a nicely done secondary. Good job!
ScotchTapeLord
Wed Mar 10 2010, 12:53AM
I think (what looks like) the scotch tape really pulls the look together ;)
Corey
Tue Mar 16 2010, 04:40AM
Finally got first light amazed most deff not tuned yet because I can only run the coil for 20 secs before the mosfet gets really warm, my tek 2335 will be here shortly soon so I can tune. I also ordered a fluke 83-5. It may be off topic but can I use any temp probe or just ones meant for my fluke? Oh yea here are some pics off my cellular device.
-Corey
Th 1268712662
Th 1268712661
Th 1268712660
Th 1268712657
Th 1268712656
Th 1268712654
Corey
Mon Mar 29 2010, 06:19PM
Still tuning i changed the gate Resistance to one ohm, theres still alot of ringing on the gate therefor not saturating the mosfet during duty. Here are some some pics of my waveforms. I believe the high freq ringing when the mosfet shuts off is the terminal blocks i have it hooked up to, tell me what you think cause i'm trying to go for a more modular system.
-Corey
Th 1269827192
Th 1269827190
Corey
Tue May 25 2010, 08:13PM
I just bought a ferrite core for my GDT.  I used 24AWG speaker wire with ten windings , i' m using one non inverting gate drive. Even  with two 12v zeners in anti- series from gate to source it still blew m y irfp460. The failure mode is .5 ohms fro m gate to source and 5.6ohms drain to sour ce. I' m thinking I might of wound it wrong with  too much leakage if someone could give som e insight that' d be awesome. Oh and these are the ferrite s i bought and i' m driving my fets at 700 khz.   cgi.ebay.com/Toroid-Cores-Power-Ferrite-88- 22mm-power-coil-x2-/180362319872? cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item29fe6e 9800
-Corey
