  • Guests: 90
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Help locating noise source, horrible TV reception.
Mon Mar 08 2010, 05:22PM
Renesis wrote ...
Proud Mary wrote ...
Yes, the box contains the RF input tuned circuit (usually striplines tuned by varicap/varactor diodes) the first Local Oscillator and the Mixer, so what comes out of the box is at the First Intermediate Frequency. I'm sure you're right to think that the same RF module is probably to be found in products from other manufacturers.
I'll be looking for a replacement then. I can see one of the ten pins is labeled AGC, which you mentioned in your first post. What voltage level should i expect to see on that pin while the TV is running?
1268065993 2028 FT85236 Pict1853
1268065994 2028 FT85236 Pict1846
My very basic knowledge of televisions doesn't go that far, I'm afraid. But the voltage should rise and fall according to the rise and fall of incoming RF from the input, so the output of the tuner unit remains fairly constant regardless of the input magnitude.
Here is a data sheet for an RF tuner module for cable TV, which may give you some ideas:
radiotech
Mon Mar 08 2010, 05:27PM
As to expected voltages while TV is running: When the set is open
and powered hazards exist. These can cause damage to the TV or your test instruments.
An isolation transformer is needed to set the reference point to earth
potential. The other thing is to makes sure all the grounding between the metal parts of the CRT bezel and aquadag (if used) is in place, especially the CRT socket board which may contain element spark gaps. If something ungrounded arcs over it can wipe out transistors.
Have fun! Troubleshooting a TV will give you loads of "street smarts" that just aren't found in the books you are studying.
Renesis
Mon Mar 08 2010, 07:15PM
Thank you everyone, this should keep me busy for a good while smile
