  • Guests: 54
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
WANTED: 833a tube socket
EEYORE
Sat Mar 06 2010, 06:37AM Print
Hello,
I need a tube socket for an 833a tube. They seem to be quite $$$ new. I am seeing prices around $50.00 plus shipping for one new socket. Anyone here have some used ones they could sell me for a better price?
Thanks,
Matt
Sat Mar 06 2010, 07:54AM
There are some from china that are abit cheaper, but this comes with 2 top caps for 35$ + shipping.
Sat Mar 06 2010, 09:00PM
I sometimes find myself unable to find a socket for specialist parts, and have developed a few techniques for dealing with the problem.
If the pins are large and far apart, I take the metal insert and its screws out of a plastic 'chocolate block' terminal block, and use these to secure the pins.
If the component generates significant heat, I drill the pin pattern through one or more fire tiles using a diamond bit, and then screw the choc block inserts
onto the pins where they come out the other side. Glass rope and glass rope adhesive used in oven door seals can be used to reinforce the ceramic
tiles where necessary.
EEYORE
Sat Mar 06 2010, 09:07PM
Proud Mary wrote ...
I also was considering building one, but figured I would wind up spending the same amount on the materials and tools in order to make it work right. frown I was going to use some aluminum clamp style electrical connectors that I found at the hardware store, but the holes are a little too small. (Now I would need to buy a large drill bit to widen the holes and thus add to the expense).
I guess I will just bite the bullet and buy one on ebay. I will deffinately treasure it!
Matt
Sat Mar 06 2010, 11:36PM
It is pretty cheap and easy to make a tube socket if you have some suitable connectors.
I needed to make a socket for the donated 4CX250BM i got from brtaman. I took apart an old socket that was made for small preamp type tubes from televisions. I cleaned the conducting surfaces up with sandpaper, but that is irrelevant. I put the connectors on the pins of the 4CX250BM and arranged them how they would be in a real socket. I took some polymer hobbiest clay, and made a flat sheet about 3-5mm thick, and i pressed it onto the base of the tube. The ends of the connectors that are to be soldered stick out, and the middle pin on the base of the tube stuck out, and there was an indention in the clay for the key to ensure the tube is inserted the correct way. I took the clay off and baked it.
I baked it a few minutes too long, so the corners burnt. I tested with 2kvac in between all of the terminals for about 10 minutes with no failures and no measurable conductivity. After warming up of the tube with a high CFM squirrel cage fan on the radiator with nothing but filament bbeing powered, it burnt the clay, but this would not happen with other tubes, seeing that their base is normally cool.
1267918576 1225 FT85176 4cx250b Socket 001
1267918576 1225 FT85176 4cx250b Socket 002
EEYORE
Sat Mar 06 2010, 11:50PM
Arcstarter wrote ...
Pretty clever of you, but the 833a is a big tube and I dont have any suitable connectors. I think I will just take a hit and go for a porcelain socket on ebay.
Thanks,
Matt
Sun Mar 07 2010, 06:48PM
Oh i am sorry tongue I guess i misread the title to say 811A.
You can however make a socket by just making clamps to clamp the filament/cathode connections and screwing that to some wood or whatever. But yea, if you have money, i would go to eBay anyway smile
Hazmatt_(The Underdog)
Sun Mar 07 2010, 10:45PM
Did you checkout Antique Electronic Supply. Their 833 sockets vary in price.
Herr Zapp
Tue Mar 09 2010, 04:00AM
Hazmatt -
Do you mean the Antique Electronic Supply at Link2
I wasn't able to find any 833A sockets here; are they located somewhere other than the tube sockets section, under vacuum tube accessories?
Regards,
Herr Zapp
