  • Guests: 42
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
IXFK 48N50Q Hoss mosfets on ebay
Russell Haley
Tue Mar 02 2010, 10:14PM Print
Russell Haley Registered Member #2478 Joined: Mon Nov 23 2009, 03:24AM
Lots of 25 for $45 shipped to the US or Canada.
Datasheet
I'm not the seller, but I did order some. They look quite beastly, although I doubt the claimed 500W dissipation is possible without liquid cooling.
brtaman
Tue Mar 02 2010, 11:26PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
Wow nice deal. Thanks for the heads up. Too bad i spent my semiconductor budget for this month already. :)
EEYORE
Wed Mar 03 2010, 01:39AM
These look to be great for a drsstc. I may have a go at some...
Matt
Wed Mar 03 2010, 02:55AM
EEYORE wrote ...
Matt
Remember, mosfets tend to be bad for drsstc's, do to the resistance. With those mosfets at room temp, you have about 120mohm on resistance. With a primary current of 400 amps, that would drop 48 volts across the mosfet. That adds up to 19kw of heat per pulse which is about 400 watts average dissipation, at 2% duty cycle. It does not sound right, but apparently it is. The mosfet itself cannot dissipate the heat that fast to the tab/heatsink, so it dies from overheating.
Sun May 02 2010, 11:45AM
It is cheap and under the limit of paying import tax to Denmark, so I gave it a shot.
I am not at all impressed of 25 MOSFETs stuck together with electrical tape in a bubble envelope letter, there is no care for static protection from the seller.
Sun May 02 2010, 01:50PM
Just be wary of cheap semiconductors nowadays on EBAY. Although IXYS usually doesn't fall under this case, many counterfeit semiconductors are hitting the market, especially those shipping over from China.
