  • Guests: 43
Tesla coil based stereo plasma sound system
1 2 3 4
Mates
Tue Mar 02 2010, 08:55PM Print
Hi guys,
I started a new project. My aim is to prove that the real super hi-fi quality based on simple resonant transformers is possible. The design employs two ungrounded (bi-polar) Tesla coils working at 4Mhz (ClassE) and amplitude modulation. The scheme is based on Reaching’s great and simple idea Link2 with certain modifications. To avoid any plasma hiss I decided to design the speakers as arc instead of streamers based. This also significantly improves the loudness while reducing the power consumption.
My general feeling from the stereo sound is really good. It still needs some optimization; probably I will need some filter to remove lower sound frequencies, those can be played by normal bass speakers anyway. On the other hand the trebles are reproduced in incredible sound quality (it must be heard to understand).
So the project is still in the beginning, now I plan to box everything up and make some nice complex sound system which could impress few of my friends with sense for a good sound reproduction and maybe even my father who is a classical music freak wink
Video: Link2
Btw: The sound quality is messed a bit by youtube movie converter…
Any questions ideas and comments are welcomed!
Cheers Mates
ragnar
Tue Mar 02 2010, 09:27PM
Mates, looks and sounds very crisp indeed! I hope this one is certainly destined for a dedicated power supply and enclosure.
Did the right-hand discharge become *louder* after interaction from the screwdriver?
raff
Wed Mar 03 2010, 03:52AM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
I have a question:
ever tried connecting the outputs to a camera FLASH bulb? (xenon?) wonder if the sound is smaller compared to open air arcs..
sportcoupe
Wed Mar 03 2010, 10:08AM
sportcoupe Registered Member #2664 Joined: Sat Jan 30 2010, 03:27PM
That is one of the coolest things I have ever seen! Thanks for sharing.
Mates
Wed Mar 03 2010, 12:37PM
Blackplasma wrote ...
Yes, the sound was bit louder. This effect is caused by the fact that by touching the elctrode I increased the distance between. Longer distance between electrodes means higher energy loss in the arc and thus louder sound.
raff wrote ...
I have a question:
No, never, but logic and experience tells me that any sound source hermetically encapsulated inside a glass chamber will be much more quite than open air. Btw: Did you ever shorten fully charged flash capacitor by a screw driver? If not I can ensure you get much louder effect than the same discharge performed inside the xenon tube wink
Wed Mar 03 2010, 03:55PM
Just keep in mind that you lose a lot of volume and lower end frequency response by having an arc/electrode arrangement. You need lots of surface area for low frequency and volume, and the electrode arc defeats this.
However, its a trade-off between notible hiss and volume.
If the frequency is high enough however, you won't have the hiss with the arcing to air.
Mates
Wed Mar 03 2010, 05:22PM
EastVoltResearch wrote ...
Actually my experience tells me the right opposite. My first attempts were of course air streamers based arrangements. I played a lot with different types of breakout points like single breakout, multiple breakouts using different wires including ultra thin tungsten wires, but I've never reached satisfactory volume. However, once I tried the arc based design the volume increased in orders while power consumption decreased significantly (actually you can try it by yourself). The absence of plasma hiss is only another extra positive about such approach. Moreover, the hiss in very high frequencies (above 10MHz) is probably not an issue, but there are other practical problems of such coils, so it is out of discussion. The only negative aspect in the “playing arc” design compared to playing streamers is that it looks a bit less attractive (to my eyes at least).
Cheers Mates
radiotech
Wed Mar 03 2010, 06:09PM
Mates wrote
"Btw: Did you ever shorten fully charged flash capacitor by a screw driver? If not I can ensure you get much louder effect than the same discharge performed inside the xenon tube "
The sound of a HV capacitor spark affects people in unpredictable ways.Unless they are part of a group accustomed to this activity,
it might cause problems. One person in a group, who was used to ship sonars, simply was struck dumb for a while. After that and other obversations, all public demos of cap sparks was dropped for good.
The demos were to show the dangers of charged caps.
Thu Mar 04 2010, 01:35AM
The bipolar coils are great btw for this providing you have enough power to get some good arc out of them. We will be offering a full class-e based kit using a a vertically mounted bipolar coil inside a custom machined plexiglas enclosure. Looks very avante-gardish and a perfect display piece. Complete with blue LED VU meter its really sweet!
We're having our machining done by monkeys down in the jungle of some third world country (trying to cut costs) so once we get delivery we'll post some pics. Of course its nice that we only need pay in bananas! :)
Mates
Mon Mar 08 2010, 08:42PM
Hi guys,
I spent some time with my new “hi-fi” toy. First of all I moved the coils away from the main driver board and I was surprised how long cables I can employ while the coils are still working. So, it looks like there will be no problem to make real satellites without the need to make separate driver with cooler for each of them. That’s the good part.
The not so good part is the sound quality. I must say, that the sound is great for the trebles and it really provides extraordinary sound experience, but unfortunately I know quite well what the real high-fidelity means. For example classical music is not reproduced so nicely. Call me a freak but I invested quite a lot of money into my home sound system (NAD amplifier and Celestion speakers) and I know why. As a problem of the plasma sound system I see very primitive way of driving the FET which is responsible for the amplitude modulation. The driver employs only one NPN transitor and I know for sure that modern hi-fi FET amplifiers working in classA use much more sophisticated way of driving the power FETs. I know it is against the rules, but maybe somebody of you know about nice scheme for a FET driver (ideally based on some low noise opamp) which could be used. What I need is a perfect control about the audio signal position related to 0V (to allow the transistor to be partially open) and control about the max voltage of the audiosignal (gain) to keep it in the linear response of the FET. Thanks
New video: Link2
1268080936 1025 FT84938 Plasma Speaker
