  • Guests: 36
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
MOTS!
radiotech
Wed Mar 03 2010, 05:13PM
This cap box (5-5-2-2-1) is rated 15ufd 600 VDC 115 VAC 10 amps 400-2400 Hz
Best of all I fished 6 of them out of a water filled scrap barrel at the university recycle/saless hut and got them free (because they were wet). Hermetically sealed and build long ago-work just fine.
1267636414 2463 FT84853 Capbox1
1267636414 2463 FT84853 Capbox2
Wed Mar 03 2010, 06:51PM
Steve,
Steve McConner wrote ...
What makes caps heat up and explode is simply I2R heating, and that's a function of the capacitor's ESR and the RMS current you try to force through it.
I thought that heating of a cap is a matter of dielectric loss for the biggest part... confused
radiotech
Thu Mar 04 2010, 07:51AM
In electrolytics the electrloyte is where most of the heat comes from but that isn't the dielectric.
Thu Mar 04 2010, 01:28PM
Dr. Kilovolt wrote ...
OK, let me rephrase that:
What makes crappy microwave oven caps, with their non-extended-foil construction and leadouts that are simply wedged into the rolled-up capacitor, heat up when used in a Tesla coil tank circuit... is mostly I2R heating from RMS current.
The dielectric in them is Mylar or something, which isn't terribly good either, but the internal resistance of the leads is much worse.
You can find other cases with other kinds of capacitors where dielectric heating does dominate.
radiotech
Thu Mar 04 2010, 07:26PM
data: SCR213 1.0MFD 1000 VOLTS PEAK 50 KHZ NO PCB'S C.D.E USA 8808. used in 12 kW induction heater module "CALCOIL'-
(changed en masse for reasons of leakage-shorting under load
even if they were good)
The blown one is GE cat 28F5371??? .25uf 2000 VPK NO PCB
stamped in metal bottom before painting case date code 79-39
both oil caps
1267730688 2463 FT84853 Capscr
