  • Guests: 71
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Capacitor Question
William Monk
Mon Mar 01 2010, 06:10AM Print
William Monk Registered Member #2470 Joined: Tue Nov 17 2009, 05:47AM
Hey Guys,
I have two 15kv 60mA transformers that i'm running in parallel. I was planning on a bank of 32 Cornell Dublier 942C20P15K-F 8 per string, 4 strings. giving me 16kV and .075 uF. I only need .0553 uF though. Do you guys think it would be better to do 10 per string and 4 strings? That would give me 20kV and .06 uF. I guess my real question here is what are the real limits as to how close the actual capacitor specifications are to the calculated specs. I am leaning towards doing the 10 x 4 array. (The 9 x 4 array seems illogical, because for only 12 dollars more why not make it a bit better) Specs on the 9 x 4 were .0666 uF 18kV. I would greatly appreciate your opinions as this is my first ever tesla coil and i dont want to have to make 10 capacitor orders, lol. Sorry if i was a retarded writer, its real late here.
Thanks,
William
William Monk
Tue Mar 02 2010, 04:51AM
Any ideas guys? Its a pretty simple question. Do you lose performance if your actual capacitance is greater than your calculated capacitance? I think that on a 15kV xformer, a 20kV cap bank will suffice (im not an expert, though).
Tue Mar 02 2010, 05:13AM
Henry H Registered Member #2298 Joined: Sat Aug 15 2009, 08:16PM
The voltage rating is fine. The capacitance should also be fine, of course you would need fewer primary turns than you would have with the lower value of capacitance (or a larger topload). That could have indirect effects on performance through greater gap losses. I wouldn't lose too much sleep over it. After it's built you can always try bypassing some capacitors to lower the overall value.
William Monk
Tue Mar 02 2010, 06:28AM
Thanks, Henry. I just really didn't want to blow up $150 worth of brand new capacitors.
Tue Mar 02 2010, 07:32AM
The 942 series are very nice capacitors, extremely robust and with self-healing properties. People have run them successfully at more than twice the voltage stress you will be putting on them.
