  • Guests: 59
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Etching tank
Dr. H.
Mon Mar 01 2010, 12:02AM Print
Good day guys
Been doing PCBs the "hard way' for more than 5 years now I've finally decided to build myself an etching tank.
It is made from 1/4 inch (6mm) plexy, has a fishtank ari pump and heater (missing on the photos) for agitating and accelerating the etching process.
Will let the glue dry overnight and test it for leaks tomorrow.
Cheers smile
1267401756 931 FT0 Dsc 0957
1267401756 931 FT0 Dsc 0970
1267401756 931 FT0 Dsc 0980
1267401756 931 FT0 Dsc 0985
Killa-X
Mon Mar 01 2010, 12:29AM
Looks good! Seen many tanks online, One person used an air-intake at the bottom and fed in air to etch, that way all the many bubbles would agitated it.
Hope the tests come through good )
Mon Mar 01 2010, 06:17AM
Looks good,
I see you learned at least 2 things in the stinking desert:
1.use acrylic
2.keep workspace tidy
Cheers, Finn Hammer
Dr. H.
Wed Mar 03 2010, 07:01AM
Hi guys
I've filled it up with water - not a single leak. The bubbler is work OK. The only thing is that it takes about hour and a half for the heater to heat up the solution ... ohh well ... will just have to switch it earlier smile
Finn Hammer wrote ...
1.use acrylic
Hee hee - I sure liked being there smile
P.S. Sorry for the bad quallity pic.
Cheers
1267599691 931 FT84815 Pic 6920
Dr. Drone
Wed Mar 03 2010, 04:39PM
shades
Dr. H.
Wed Mar 03 2010, 09:26PM
Hi sir
Dr. Spark wrote ...
Nice tank, only issue I see is no blue LED’s.
I doubt those will accelerate the etching speed cheesey
I was actually thinking of putting a few LED but don't have low voltage supply on the tank.
Cheers smile
ragnar
Wed Mar 03 2010, 09:35PM
Dr. H. wrote ...
If the heating element is within the tank, there's a big resistive divider and should be able to choose any suitable tap; no excuses now... :P
Dr. H.
Thu Mar 04 2010, 09:56AM
Darn ... you got me ..... cheesey
shoud I risk electrocution for few LEDs .... CERTAINLY cheesey
Have a great day guys smile
Sat Mar 06 2010, 03:50PM
I am also building my own etching tank using recycled glass harvested from dead HP printers.
the cool part is that the volume of etchant is minimal and am also using a peristaltic pump kludged from a spare fan motor and Polymorph, as well as some aquarium tubing.
In restrospect, maybe I should have made some glass end plates and siliconed those, as there is a taper on the glass now.
has anyone managed to integrate an ultrasonic cleaner into an etching tank? this would be an effective way to rinse a board while ensuring that any remaining etchant was flushed away before it causes corrosion.
fwiw make sure you leave it long enough to get rid of the vinegar fumes, as they eat copper right through the resist. Don't ask :)
EDIT: It no longer leaks :) I have left it for a day and seems fine.
I did have a thought a while ago about a "one step" laser etcher and processor, that exposes the PCB through the glass (would require some innovative pumping however) so the process would be expose, develop PCB (maybe combine the two if silicate is used), then flush out developer when complete , etch then flush/agitate with water.
the main reason for integrating the two steps is that the presence of an air gap does nasty things to the board, my inspiration is the use of water when doing uv pcb exposure to hold the acetate in place by surface tension..
For various reasons it might be easier to run the setup horizontally, then use alignment marks for the software to correctly index the board.
Sound possible?
-A
"Bother" said Pooh, as he flashed his BIOS with W32.Nimda...
Dr. H.
Sun Mar 28 2010, 07:19PM
Good day guys
Conundrum - glad to hear your tank is coming together smile also you've got a pretty interesting idea.
Some info - today I've finally tested the tank. Filled it with 2.5 liters of solution (sodium persulfate) and placed the boards. It took about 7 minutes to etched them at fairly cold solution (about 26 deg C - it was pretty cold outside (around 8C )). I've etched a total of 6 quite big boards and it is working PERFECTLY - much faster and cleaner than with the FeCl3. Also the qullity of the traces is much better and the permenent marker stands better - maybe because it dosn't have enough time to desolv.
All in all - I am REALLY HAPPY with the result cheesey Will *never* use FeCl3 again.
Cheers smile
1269803962 931 FT84815 Dsc05103
